Trying To Modify A Generac GP3300 Need Electrician - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2014, 06:02 PM   #1
Trying to modify a Generac GP3300 Need Electrician
I own a Generac GP3300 portable generator. It has 1 120/240 30amp receptacle and 4 120v 14amp receptacles. Upon opening the cover I discovered two 14amp breakers.
I'm no electrician, but I'm smart enough to follow direction. So help me out DIYnosaurs.
I want to increase the amperage of the 4 120v receptacles from 14 amp to 20 amp. Now I realize that this will mean that I need to change the 14g wiring to something like 12-10 from the breakers to the receptacles to carry the load if this even works. But what about the wiring from the generator to the breakers?
This is a serious inquiry. I wanna get the most bang for my buck since I'm stuck with this thing.
lhoage is offline   Reply With Quote
Old 06-13-2014, 07:08 PM   #2
Rewards Points: 332
There's a good chance that half of those 120v receptacles are on one leg, the other half on the other leg. That would give you 28A total. It just depends on how it's all wired.
sgip2000 is offline   Reply With Quote
Old 06-13-2014, 07:19 PM   #3
Rewards Points: 3,396
So you will rewire and protect it all at 20amp.
How will you make it create more?
3300 / 240 = 13.75
interesting unit.
20 amp 120 v duplex receptacles on the 14 amp.
looks like 20 amp 240v 4 wire receptacle but specs claim it's 30 amp?
I was thinking, get a 30 amp cap for the outlet into a 2 circuit enclosure to a 2 pole 20 breaker to a double duplex outlet.
but again. 13.75
sell it.
take the money and apply it toward what you want.
ritelec is offline   Reply With Quote
Old 06-13-2014, 07:29 PM   #4
actually specs show 3300-5000 (20.8 amps)
not sure how it's wired that it could run at 20 and the breakers are at 14?
Have you been having issues the way it is?
You could go nuts, and rewire, but why. was what $450 bucks
sell it or give it to someone as a present (or keep it) and get the one that suites you better.
Old 06-13-2014, 07:42 PM   #5
Engine: .unitedpower.de.com/en/node/244 add www
Some Evaluation .arb.ca.gov/msprog/offroad/cert/eo/2014/sore/u-u-125-0088.pdf add www
It looks as if they have one breaker on red, and one on black. They both tie into the rv outlet, which then splits from the rv outlet to each receptacle, one black and one red.
Old 06-13-2014, 07:54 PM   #6
yes..
at 14 amp.
protecting the generator for the way they designed it
Old 06-13-2014, 08:11 PM   #7
So the two 14amp breakers split across the rv outlet don't give it 30 amps? (Roughly)
Old 06-14-2014, 05:37 AM   #8
dmxtothemax's Avatar
Rewards Points: 5,608
Is the second set of breakers in your panel ?
What loads are you likely to run of the genny ?
Are they 120v or 240v ?
Remember the set amount of power,
so at the higher voltage you get lower current.
3300/120 = 27.5A
3300/240 = 13.75A
Do you know what size the existing wires are ?
dmxtothemax is offline   Reply With Quote
Old 06-14-2014, 05:58 AM   #9
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Why anyone would give any advice other than "sell it" or "live with it" is beyond me.
Old 06-14-2014, 06:18 AM   #10
An old Tradesmen
Rewards Points: 8,234
I think sometimes its in the nature of people to try and make something work in a manor it was never intended or design to do.
Old 06-14-2014, 07:38 AM   #11
Gentlemen, this is why it is called "tinkering".
Ahem.
The wiring is 14g. There are two 14amp breakers. I won't be using anything except 120v
Old 06-14-2014, 07:45 AM   #12
An old Tradesmen
2-14amp circuits(drawing 14 amps at 120 volts) is 3360 watts. So no need to replace those breakers with 20 amp breakers.
Old 06-14-2014, 07:45 AM   #13
Rewards Points: 386
if the generator is limted to 15 amps per leg, then this all you will get. changing the breaker & wire size will do no good.if anything it will lead to damage of the generator.
circuitman is online now   Reply With Quote
Old 06-14-2014, 09:44 AM   #14
Well, what I wanted to accomplish is to have a single 20 amp breaker feeding a single receptacle. I would just change this out back to the two 14 amps depending on the work load.
It seems that the way this is designed is not possible. As you are saying, I'm getting 14 amps from the motor on each wire. Getting a thicker gauge wire won't help the issue, it will just transfer 14 amps on each leg through that thicker wire anyways.
I appreciate the help in this matter. I'm not an electrician clearly. I'm a metalworker. I was just trying to make something work by recognizing a pattern in the design.
Old 06-14-2014, 12:36 PM   #15
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
If it was designed to be on a 20 amp breaker, it would have come with a 20 amp breaker..... if anything, make a temporary sub panel up and plug that into the 120/240v 30 amp receptacle...
Generac 8kw Standby in the winter? Toller Electrical 7 08-01-2013 10:02 PM
Generac GP5500 a bust?? Ultrarunner2017 Electrical 11 12-21-2012 05:53 PM
Generac Install ????? herdfan Electrical 0 07-07-2012 05:01 PM
How Hard is it to Modify RTA Cabinets? mystic_cobra Carpentry 16 03-07-2012 08:53 AM
Generac 10KW generator and Generac RTS12EZA1 transfer switch. exhdo1 Electrical 8 11-30-2011 02:33 PM
