Trying To Install Leviton In-Wall LCD Timer Switch - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-05-2009, 12:17 PM   #31
Rewards Points: 54
Here's an updated picture. Thanks to everyone for spending time on this! Yes I could call an electrician, but I'm curious about this stuff and I like to learn. So with my limited knowledge, and to demonstrate I'm trying here, I think I have to do this:
Connect the hot wire in one nut to the Other, Light, and Fan wires (for the Light and Fan, to the wires that are meant for the Hot wire).
Connect the Light Neutral wire to the wire in the upper left.
Connect the Fan Neutral wire to the wire in the upper right.
Put electrical tape over the stripped section of wire in the middle of the Other wire to prevent shorting the circuit.
kripes is offline   Reply With Quote
Old 11-05-2009, 12:17 PM   #32
Rewards Points: 54
Forgot attachment
Old 11-05-2009, 02:00 PM   #33
Git
The HOT wire should be wire nutted to these wires:
1) Your "other fixtures" wire
2) The black wire from the fan switch
3) One of the black wires from the dimmer switch
The FAN wire should be connected to the BLUE LOAD wire on the fan switch - I am assuming the fan switchis the silver colored switch on the right
Your LIGHT wire would get connected to the other black wire on your dimmer switch
Green wires get connected to the metal work box - and any ground wires present in the circuit
All the white neutral wires get connected together and wire nutted as is
Git is offline   Reply With Quote
Old 11-05-2009, 08:16 PM   #34
Rewards Points: 54
Did all that, same result (the fan is always on). So either I have a bad unit, or there's an undocumented "always on" switch inside the unit. In any case, I'm going to get a 20A instead and try that.
I'll keep you all posted.
Old 11-05-2009, 09:32 PM   #35
Thumbs up
What do you mean by "The fan is always ON? !Regardless of what everyone (including myself) advised before! a) determine (by simple method of "pigtail" socket & bulb) Which is HOT; b) Attach Black wire of Timer to "HOT" lead; c) (assuming, and taken for granted that you attached White wire of Timer to NEUTRAL wires in the box) Attach Blue wire of Timer to Black wire in J. Box that feeds the FAN: Oh. There's one small detail that you might have overlooked. Stabilize the Timer. Meaning. Attach the timer (w. the 6-32 screws) albeit temporarily to the Box. since these timers have Mercury switches, shaking them might make them go ON even though they're in the OFF position! (No matter what) Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 11-05-2009, 10:14 PM   #36
Rewards Points: 54
Well, that was it. When I installed a 20A switch, it worked like a charm the first time. Bloody odd.
Thanks everyone!!!
Old 11-05-2009, 10:15 PM   #37
Rewards Points: 54
fltdek, I can't respond to your PM because I don't have 20 posts yet on the forums. I wasn't ignoring you.
Tags
lcd , leviton , light , switch , timer
need to find wall switch remote..does that exist? tarheelblue Electrical 7 09-05-2008 05:51 AM
Fluorescent lamp requires wall switch to be cycled several times before lighting. joejean Electrical 5 09-04-2008 08:48 AM
Install an electronic timer CaJazzman Electrical 8 08-13-2008 04:12 PM
ceiling fixture with on-off wall switch carlu Electrical 1 03-04-2005 08:13 AM
Wall Switch sue Electrical 4 02-06-2005 07:05 PM
