Trying To Fix Space Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 04:13 PM   #1
trying to fix space heater
Someone threw away a small oil-filled space heater. It looks pretty new but it does not work. I am trying to fix it because it would be perfect for our guest room.
Do heaters like this have fuses? Where is the fuse in the photo? Are there other typical reasons why such heaters stop working?
Thanks much
ilyaz is offline   Reply With Quote
Old 11-29-2010, 04:26 PM   #2
I=E/R
a7ecorsair's Avatar
There probably isn't any fuse inside the unit - I don't see anything that looks like a fuse. You will need a voltmeter to troubleshoot this thing. Connect one lead to the neutral line on the incoming bus bar and then use the other lead to check the loop. Just follow the the wire around. It looks like there is an over temperature device.
I don't know your skill working around electricity but remember there will be live power.
a7ecorsair is offline   Reply With Quote
Old 11-29-2010, 04:29 PM   #3
WDR
heater
it could be the heating element that heats the oil.
WDR is offline   Reply With Quote
Old 11-29-2010, 04:57 PM   #4
And Still Learning
That's what I was thinking. Check ohms on the element.
Know It ALL is offline   Reply With Quote
Old 11-29-2010, 08:29 PM   #5
" Euro " electrician
frenchelectrican's Avatar
If the heating elements are good { this unit will have two elements } then you have limit switch go bad that is the other spot you will have to find and it is very visbale on the photo and that thermal switch I think it is a one time use { non resetable } and you have to concat the manufacter for the correct thermal switch.
Merci,
Marc
Natural Gas Heater and Lines Leroy1985 HVAC 14 11-11-2010 10:08 PM
Crawl space gas leak WillK Plumbing 13 10-19-2010 09:58 AM
Which Gas Hot Water Heater walds11 Plumbing 66 01-16-2010 07:38 AM
Can I run a small (500 watt) 240 V space heater at 120V? pcampbell Electrical 6 01-08-2009 09:56 PM
I would like to relocate the flue for my gas water heater Git HVAC 12 04-23-2008 09:37 PM
