Trying To Find Electrical Panel Cover - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2013, 08:29 AM   #1
Trying to find Electrical Panel Cover
I am trying to find a Electrical Panel Cover for a home that was built in 1960. I am not sure how old this panel is, but I am trying to figure out what type of panel it is.
There is no indication of what kind of panel, but a recent update to a fuse was a Murray 04089253198.
Inside the Panel Box states Underwriter Labratories CTL ff 038292, and 11 box3501.
Is anyone familiar with what type of Panel this is???? Please help???? Need to replace the cover.
amy1234567 is offline   Reply With Quote
Old 08-04-2013, 08:44 AM   #2
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
LOL ... no no .. you need to replace the Panel and then you get a free cover ....
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
The Following 2 Users Say Thank You to Philly Master For This Useful Post:
gregzoll (08-04-2013), Speedy Petey (08-04-2013)
Old 08-04-2013, 08:53 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
Yeah, your only option is to do the right thing and have that panel replaced. This way they can move it down from being tucked up into the ceiling like that. That is a REAL hack job.
Besides, you'll never find a cover for it unless someone has a junk one lying around, which is not likely.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
gregzoll (08-04-2013), jbfan (08-04-2013)
Old 08-04-2013, 08:57 AM   #4
Philly
Thanks Philly. We would have upgraded the panel, but we are selling the house and was looking to find a replacement cover.
I bought 2 Murray Panels, but the covers do not fit correctly over the interior box. I am not very savvy with electrical so I was trying to see if it were possible to get a replacement cover?
If I were familiar with the brand it was it would be easier to search to see if I can find it online. I was hoping someone on this site might be familiar with the picture of the kind of panel?
Thanks though!
Old 08-04-2013, 08:59 AM   #5
Another reason to have it replaced. A home inspector will rip that panel to shreds. You're better off making the proactive move to avoid that.
Like we said, it's simply too old.
Oh, I'm sure we're all very familiar with those panels.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Old 08-04-2013, 09:21 AM   #6
Rewards Points: 516
LOL its a 12/24
Old 08-04-2013, 10:41 AM   #7
Thanks speedy and philly. I will look into finding a replacement cover still to see if anyone has any sitting around and how much it would cost to replace the housing.
Old 08-04-2013, 10:42 AM   #8
Rewards Points: 282
A new cover would ease the concerns of a potential home buyer such that they make an offer, but a home inspector and/or FHA appraiser would require replacement of the panel or at least updates. That could, however, become a point of negotiation on price.
dgfit is offline   Reply With Quote
Old 08-04-2013, 10:47 AM   #9
dgfit, I don't have any current issues with the electrical or tripping of service. Do you see something of concern? It's an older panel, but I don't have any issues with it, I was just trying to find a cover for it.
Old 08-04-2013, 10:50 AM   #10
I recently had a FHA loan in buying the house a year ago, but I need to relocate for job reasons and was concerned about the cover.
Old 08-04-2013, 11:51 AM   #11
Oso954's Avatar
Rewards Points: 1,610
Apparently, your home inspector missed the issues.
The panel is mounted too high from the floor (assuming normal ceiling) height.
It extends above the ceiling, making panel cover removal next to impossible. That is the reason someone cut down your current cover.
Your current cover does not completely seal the panel. If you had an arc, it would jet out the opening above the panel cover and most likely set the house on fire.
Everything about that panel says some Hack did the work. That begs the question "What else did he do that I can't see ?" I would be asking you for a larger price reduction than the panel replacement, simply because I know I would run into more wiring issues in the future. If I was advising someone else, I would probably say walk away, find another house.
That is why the guys are telling you to replace it before inspection.
Putting a new cover on it, is putting lipstick on a pig.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Old 08-04-2013, 12:25 PM   #12
Sparkaholic
Rewards Points: 150
Send a message via Yahoo to sparks1up
In lieu of replacing the panel you could always raise the ceiling and the floor, replace the breakers with all from the same manufacturer, install proper fittings at cable entries, make sure the panel is properly bonded and grounded and replace the cover... Probably less work to replace the panel...
The panel has a Bryant main breaker and a mixture of Siemens, Crouse Hinds and Bryant branch breakers.
Have fun!
Answers based on the mood I am in when you ask!
sparks1up is offline   Reply With Quote
Old 08-04-2013, 02:35 PM   #13
Rewards Points: 282
I think it all depends on the inspector/appraiser. They should call out anything unsafe and likely respect grandfathered code. Dunno when the panel height code came out in relation to when the panel was installed.
Old 08-04-2013, 02:44 PM   #14
Rewards Points: 6,652
Have fun with that. You will never find one. Again, better to replace the panel, and then you will have no problems.
Why make things more difficult by fighting the Sparky's that have responded, who know what they are talking about, thinking that you are going to find a dead front door for a panel, that is no longer manufactured.
BTW, you have the Dead Front, you just need a door to over, which you can actually just have a shop that has a hydraulic metal shear, cut one out of 18 gauge steel, and then rivet on hinges, that you can rivet on that existing Dead Front.
Old 08-04-2013, 02:47 PM   #15
Oso954's Avatar
......in relation to when the panel was installed.
You apparently don't realize you are NOT looking at an original panel that was permitted and inspected. This is a replacement that was most likely done without permit, because it should have never passed inspection.
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
Square D panel cover dougie-r Electrical 0 04-12-2011 09:40 PM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
How to add 220 line to my electrical panel? river251 General DIY Discussions 11 05-02-2010 09:23 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
