Trying To Figure Out Some Confusing Wiring - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-10-2010, 09:38 PM   #16
Originally Posted by gnosti83 View Post
my guess is it was a switched outlet at one point on a 3wire to that outlet. It has since been replaced and the black now feeds the whole outlet making the red wire worthless. Make sure to remove that black pigtail.
That's probably right. Probably what I should do if possible is find which outlet the red wire goes to and disconnect it so its not hot at the switch panel. Worst case is that the red wire just gets connected up with the other two black wires, which are in turn all connected to the input of the dimmer switch. The dimmer would go in place of the switch that's there now, and the additional wire that's run up the wall to the recessed lights would be connected to the output of the dimmer switch.
Eric123 is offline   Reply With Quote
Old 03-10-2010, 09:43 PM   #17
Master Electrician
Rewards Points: 3,820
Originally Posted by Eric123 View Post
Yep. they sure were.
Then I find it hard to believe that they are both hot unless someone has done some funky splicing somewhere else. I still vote for switched receptacles. What room is nearest to the switchbox.?
brric is online now   Reply With Quote
Old 03-11-2010, 07:00 AM   #18
Believe it, they're both hot. The switched outlet theory seems the most likely. Someone may have jumpered the black wire to the switched outlet at some point and left the red wire attached. I'll open some outlets and take a look when I get a chance.
Old 03-11-2010, 10:02 AM   #19
I assumed the red was not hot. The word doc said that the red was hot when the switch was powered, i assumed the black was feeding the red. You are saying that even disconnected the red and the black both draw power? If that is the case then the black needs to be removed, and u need to search all ur junctions/outlets and look where that red is tied in and remove that one as well.
gnosti83 is offline   Reply With Quote
Old 03-11-2010, 05:28 PM   #20
Yes both of the leads that connect to the switch, the red and black one, are hot even when disconected from the switch. i agree that I need to track that red wire down
Old 03-11-2010, 05:37 PM   #21
joed's Avatar
Rewards Points: 12,402
If both leads are hot it is likely that there is a half switched receptacle (or several) in the room that someone replaced and did not break the tab.
Old 03-11-2010, 05:52 PM   #22
if you dont want to unscrew the outlets, u can remove the black that is in the same wire set as the red and test for the dead outlet or light.
Old 03-11-2010, 08:21 PM   #23
I took out all the outlets in the basement on that circuit tonight and didn't find a red wire anywhere.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Wiring gone bad??? Dishwasher issue beginnerDIY Electrical 38 09-06-2009 07:30 AM
trying to figure out some wiring december45 Electrical 2 05-12-2009 09:54 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
