Trying To Figure Out Some Confusing Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 03-10-2010, 06:09 PM   #1
Trying to figure out some confusing wiring
I'm thinking about putting some lights down in my basement and I wanted to put a dimmer switch on the swich panel in question. I've never known what "switch a" does and when I opened the panel up and checked out the wiring I was more confused. I recognize that "switch b" is a two way switch but what is the purpose of "switch a"?
Eric123 is offline   Reply With Quote
Old 03-10-2010, 06:18 PM   #2
Master Electrician
Rewards Points: 3,874
Right now it controls nothing, there are no wires connected to it. Possibly half switched receptacles in the living room?????? Exterior light fixture?????
brric is online now   Reply With Quote
Old 03-10-2010, 06:49 PM   #3
joed's Avatar
Rewards Points: 12,904
Looks it might have been connected to the red and black at one time. Is there a ceiling fixture in the room. Could be the unused control for a future fan light combo. The switch was put in as a blank filler.
Old 03-10-2010, 08:31 PM   #4
There's no ceiling fixture. Guess I can use that spot for a dimmer then.
Old 03-10-2010, 08:44 PM   #5
my guess is it was a switched outlet at one point on a 3wire to that outlet. It has since been replaced and the black now feeds the whole outlet making the red wire worthless. Make sure to remove that black pigtail.
gnosti83 is offline   Reply With Quote
Old 03-10-2010, 08:49 PM   #6
Master Electrician
[quote=Eric123;412855]There's no ceiling fixture. Guess I can use that spot for a dimmer then.[/quot
Old 03-10-2010, 08:57 PM   #7
Arrow
No. You don't use a dimmer and regular (toggle) switch. The Dimmer replaces the switch. One word of caution, however. With a dimmer switch, you can not use any inductive load. Meaning a ceiling fan or fluorescent lights. Including CFL. If you DO try to use, you're risking a fire! the only lights you can use are; Incandescent bulbs or Halogen!!
spark plug is offline   Reply With Quote
Old 03-10-2010, 08:58 PM   #8
" Euro " electrician
frenchelectrican's Avatar
Senice the OP mention no ceiling luminaire at all so I am more leaning toward to switched receptales the sure fire way you can tell is go to the nearest recetpale { turn off the breaker on this one } and pull it out but DO NOT discoonect any wire but look inside if you do see red wire hook up or not.
If red wire is there then a good chance you have switched receptale.
Merci,Marc
Old 03-10-2010, 09:07 PM   #9
Let me explain from the beginning. The first floor of my house only extends to within about 6 feet of the back wall. So there is an overlook down into my basement. I've been planning on extending the floor to the wall to gain some square footage. I want to install recessed lighting in the basement where the newly installed floor/ceiling will be. I was thinking of running wires up from the switch panel and distributing lines to several recessed lights. Thats why I want a dimmer switch there. That's also why I was trying to figure out what that switch was for. If it does nothing then I guess I can simply take the switch out, connect the red and black wires together, and run another line up the wall and over the basement?
Old 03-10-2010, 09:10 PM   #10
By the way, I'm taking it slow and planning on getting a permit for all this. I'm just in the planning stage.
Old 03-10-2010, 09:19 PM   #11
if you dont know where that line goes, its prolly not a smart idea to make that a permanently hot line. If nothing is losing power with it being disconnected, remove the black and leave the red.
Old 03-10-2010, 09:23 PM   #12
Master Electrician
Were the wires connected to the switch when you removed it from the switch box?
Old 03-10-2010, 09:25 PM   #13
Remember that the red wire is hot. What would be the proper way to cover up an unused hot wire in an electical box?
Old 03-10-2010, 09:27 PM   #14
Yep. they sure were.
Old 03-10-2010, 09:30 PM   #15
Master Electrician
Were the wires connected to the switch when you removed it from the box?
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Wiring gone bad??? Dishwasher issue beginnerDIY Electrical 38 09-06-2009 07:30 AM
trying to figure out some wiring december45 Electrical 2 05-12-2009 09:54 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
