Old 04-12-2009, 08:55 AM   #1
Trying to create a nichrome coil heater that runs off cr123 batts
rgsgrgsrg sg sg sg seg seg
freddo is offline   Reply With Quote
Old 04-12-2009, 09:48 AM   #2
It was a dark and stormy
Yoyizit's Avatar
Originally Posted by freddo View Post
Ok, so what i am trying to do is create a mini nichrome coil heater that runs of 2xcr123 batt's and can heat up to to turn propylene glycol into vapour. Basically lke a mini fog machine.
Latent heat of vaporization: 101.3kpa (respectively 60.5mpa. 19) 2.49KJ / kg
° ree; C and 711KJ / kg
How fast you want this process to work?
Old 04-12-2009, 09:54 AM   #3
Ok i just found out that
Propylene GlycolBoiling Point: 188.2 °C
I need it to get to that temprature within a matter of seconds. If possible 1 sec.
Thanks for the speedy response
Hopefully i want the batts to be around 3.6v with a rating of around 1200 mah
Old 04-12-2009, 09:57 AM   #4
Would this nichrome wire be suitable?
http://cgi.ebay.co.uk/Nichrome-Resis...3A1|240%3A1318
Old 04-12-2009, 10:23 AM   #5
Yoyizit's Avatar
You need 1 btu per pound per °F.
188°C = [(188+40)(9/5)]-40 = 370°F
so for one pound of this stuff you need to input 370 btus =
http://www.onlineconversion.com/
108 watt hours of energy.
108 w-h is 1080 w for 6 minutes is 10,800 w for 3.6 sec is 39 kW for 1 second, about as much as 40 residences take each second.
Sounds impractical.
Which design constraint would you like to relax?
Old 04-12-2009, 10:31 AM   #6
lol...hmm....any suggestions?
Old 04-12-2009, 10:34 AM   #7
Yoyizit's Avatar
Less fog? More time? Both?
Old 04-12-2009, 10:36 AM   #8
It doesnt have to have a hell of alot of fog. What i am trying to do is create a new heating coil for my electronic cigarette, a portable vaporizer. This will probably give you a clearer understanding of what i'm after.
Old 04-12-2009, 10:43 AM   #9
Yoyizit's Avatar
Your battery is 6v 1.6 A-h which is 10 w-h. Practically you could get 1 w for 10 hours from these two cells.
Old 04-12-2009, 11:09 AM   #10
How about these batts http://www.bestofferbuy.com/TrustFir...campaign=gbase
Old 04-12-2009, 01:21 PM   #11
Yoyizit's Avatar
3.3 w-h per cell.
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
