Old 12-16-2012, 01:12 PM   #1
Trying to change a light switch
I thought changing a light switch would be as easy as disconnecting the old switch and connecting the new one with the same configuration. There were three black wires connected to the old switch, one of which was hot. The white wires were tied together with a wire nut in the box.
With the new switch in place it now seems to control every outlet and switch in the room. What did I do wrong?
imnotaplumber is offline   Reply With Quote
Old 12-16-2012, 01:23 PM   #2
E2 Electrician
stickboy1375's Avatar
You touched it... You obviously remade the existing splice.
Old 12-16-2012, 01:24 PM   #3
It is.
hammerlane is offline   Reply With Quote
Old 12-16-2012, 02:01 PM   #4
joed's Avatar
The connection with two wires has the wrong two. Take one of them and put it with the single one. If the switch controls the receptacles instead of the fixture you got the wrong one. Swap it with the other one.
Do not PM with questions that can be asked in a forum. I will not respond.
light switch won't turn off light nredburn Electrical 4 11-20-2012 08:45 PM
3 way switch -OK to drop down neutral like this to light through switch box via 12/3? darlingm Electrical 9 12-22-2011 03:48 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 50 09-01-2009 09:20 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 10:02 AM
