Troubleshooting PS2350295 Circuit Board - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2011, 09:18 PM   #1
troubleshooting PS2350295 circuit board
My dishwasher door panel will not light up or turn on! It does not supply power to my control panel and light the panel up.
How do test my PS2350295 circuit board for faulty components?
It is the board for my Maytag dishwasher, model mdb5601awb maytag quiet series 300. i replaced my broken door handle thinking that was the problem. but still don't have led lighting up.
James
jwauneka is offline   Reply With Quote
Old 09-16-2011, 11:20 AM   #2
Rewards Points: 160
Do you have electronic experience? Particularly component level experience? If not, why not replace the board and see if it fixes the problem. I mean what else can you do except call in a repair man.
Old 09-16-2011, 12:27 PM   #3
I=E/R
a7ecorsair's Avatar
James
To troubleshoot this you will need a schematic diagram and a multimeter. Are you versed in component level electrical work and reading schematics?
You said the door handle was broken. Did this problem show up when the handle broke? The door handle linkage most likely operates some type of mechanical switch which would be an input to the control board. Have you looked for some type of switch that is actuated by the handle?
a7ecorsair is offline   Reply With Quote
Is it possible to change Circuit breaker to Buss fuse socket type? njchen24 Electrical 8 08-07-2011 06:27 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Tempstar Air Conditioner Bad Circuit Board SCVOL HVAC 7 10-04-2010 05:14 PM
Apparently I need a new circuit board? PeteUSA44 HVAC 5 10-18-2009 07:56 PM
DIY recommendation for Goodman Control Module (Circuit Board) njwaves HVAC 3 09-26-2009 07:29 AM
