Troubleshooting Fluorescent Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 07-10-2012, 07:33 PM   #1
Troubleshooting Fluorescent lights
Does anyone have any good resources or electrical diagrams for checking a 120 volt residential fluorescent light fixture with a meter? I am very well versed in the use of an electrical meter,but am in need of some assistance when it comes to this fixture.Any help is greatly appreciated!!!!
Servicewiz is offline   Reply With Quote
Old 07-10-2012, 07:35 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Check power to the ballast. If yes...
Replace the lamps. If lamps are still not lighting...
Replace ballast.
The Following User Says Thank You to k_buz For This Useful Post:
jbfan (07-11-2012)
Old 07-10-2012, 11:27 PM   #3
Rewards Points: 156
Some older florescent lamps also use a small capacitor in them too. The capacitor is replaceable at your local hardware store for a few bucks. If the light continues to flicker and flash after you install a new bulb, check for one of these too.
av-geek is offline   Reply With Quote
Old 07-10-2012, 11:28 PM   #4
joed's Avatar
Rewards Points: 12,018
Replace ballast.
That's my test procedure exactly.
Old 07-11-2012, 01:42 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,162
Replace ballast.
You guys are almost right...but missed a few steps....
Fluorescent light does not come on....go grab a beer and look at it for a few minutes. Maybe it just needs a little time....
Still not on? If beer is finished, go get another one. Then go to garage and get a new tube. Because beer is in one hand, you can only carry one tube so it takes two trips.
Time to put in bulb....because it took two trips to the garage, beer is done, time for another beer.
Ok....1st tube is in.....beer is done, go get another beer.
Second tube is in.....time to try it....oh, wait....beer is done...go get another one.
Ok....time to try the lights. Turn on switch....wait for light. If lights do not turn on by the time you finsh the beer....ballast is most likely bad.
Drive to the HW store and try not to get stopped by the police.
Go to the bathroom at least twice while in the hardware store (lot of beer to get rid of).
Drive home....celibrate not getting arrested for DUI by having another beer.
Ok...time to put in ballast......go to garage and get tools. This takes several trips because you only have one hand to carry tools...beer is in the other one.
Beer is done...time for another one.
Ok....time to remove old ballast...climb up on ladder....remove bulbs and cover....disconnect wires....get shocked (forgot to turn off power)....fall off ladder....but not hurt too bad....alcohol dampens the pain....
Have another beer while the pain goes away.
Pain gone (feel no pain...period)...make sure power is iff...climb back up...replace ballast.....install new tubes.....have another beer.
Beer done....time to try it....flip the switch...circuit breaker blows....wife yells....you stumble in the dark because you can't see...and your drunk....fall down...smack you head on the floor.....
You wake up the next morning still on the floor (wife was pissed that you were so drunk)....you go call Sparky to come fix it.....
Now, where was the other case of beer?
The Following User Says Thank You to ddawg16 For This Useful Post:
jbfan (07-11-2012)
Old 07-11-2012, 09:49 AM   #6
Rewards Points: 266
Originally Posted by av-geek View Post
Some older florescent lamps also use a small capacitor....
Capacitor or starter?
OP, if you touch the bulb and the lamp strikes, you need to ground the case of the fixture better.
Otherwise, what buzz or ddwag wrote. Keep in mind that your switch could be shot if one luminaire is on it, but checking power to ballast will cover that. Checking the lamp-ballast leads is tough. The ballasts go through a lot of gymnastics to start the lamp and they are different depending on the ballast type. If you need a replacement ballast, check the wiring diagram on the existing one before you shop. You should really switch to T8 ballast and bulb if this is a 4' T12 fixture and you need a ballast change.
ionized is offline   Reply With Quote
Fluorescent lights ozbuc Electrical 4 01-24-2012 03:41 PM
Fluorescent lights don't seem to last preciouschristy Electrical 20 01-10-2012 09:47 AM
Kitchen fluorescent to LED recessed lighting changeout speedytahiti Electrical 1 01-05-2012 08:04 PM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 01:35 PM
Under cabinet lights dismas Electrical 3 01-15-2010 04:52 PM
