Troubleshooting Fluorescent Ballast? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-13-2012, 06:10 PM   #1
Rewards Points: 506
Troubleshooting fluorescent ballast?
A 3 lamp fluorescent fixture stopped giving light.
1st action = new tubes. Result = no light.
2nd action = verify input voltage. Result = 120v line to neutral.
3rd action = go to DIY Chatroom and ask if a procedure exists to verify the proper function of the ballast (besides the light tubes). Result = ???
jlmran is offline   Reply With Quote
Old 12-13-2012, 06:15 PM   #2
joed's Avatar
Rewards Points: 13,752
Change the ballast. The tubes don't light and you have input power. The ballast is bad unless you new tubes are bad. You could try them in a different fixture.
Standard fluorescent repair procedure.
1. Change the lamps. No light see #2.
2. change the ballast.
The Following 2 Users Say Thank You to joed For This Useful Post:
jbfan (12-13-2012), micromind (12-13-2012)
Old 12-13-2012, 07:57 PM   #3
Electrician
Rewards Points: 802
4th action-change the ballast
darren is offline   Reply With Quote
Old 12-13-2012, 11:13 PM   #4
" Euro " electrician
frenchelectrican's Avatar
5Th action .,, Make sure the wiring diagram is match up to the tombstone connection and also use the correct lamps as it will listed in the ballast housing.
Merci,
Marc
fluorescent ballast change question herf Electrical 8 04-14-2012 08:07 AM
Fluorescent Ballast Tricks? K|O|G|I Electrical 16 02-23-2011 07:50 PM
Changing Kitchen Light - Fluorescent Ballast llmercll Electrical 23 02-08-2011 10:45 AM
No ballast in 48 inch fluorescent fixture. Timster Electrical 16 06-10-2010 04:02 AM
New Fluorescent Ballast trips GFCI Breaker?? marc515 Electrical 7 02-18-2010 04:42 PM
