Troubleshooting - Electrical - DIY Chatroom Home Improvement Forum
Closed Thread
Old 09-14-2012, 11:30 PM   #1
troubleshooting
Receptacle out in living room on first floor.
Finished second floor above.
Finished basement below.
No work has been done recently.
You opened the other receptacle/switch/light boxes in the room and adjacent rooms and can't find anything loose.
What do you do?
NECHater is offline
Old 09-15-2012, 04:51 AM   #2
custom user
Rewards Points: 150
Take out my meter and check voltages. A visual look may not do it, especially if they are back stabbed.
JasperST is offline
Old 09-15-2012, 08:08 AM   #3
Nothing found. Next step?
NECHater is offline
Old 09-15-2012, 08:17 AM   #4
custom user
Rewards Points: 150
No electricity found? I'd look for a tripped breaker.
JasperST is offline
Old 09-15-2012, 08:29 AM   #5
Resi EC
Rewards Points: 252
Find the closest working receptacle/switch check connections in it.
May be the next one on the wall, could even be on the opposite side of wall (if wall is common to another room)
Gac66610 is offline
Old 09-15-2012, 09:13 AM   #6
First post:
NECHater is offline
Old 09-15-2012, 09:15 AM   #7
None. Next.
NECHater is offline
Old 09-15-2012, 10:12 AM   #8
An old Tradesmen
Rewards Points: 7,816
Check for tripped GFCIs in the kitchen and bathroom.
beenthere is offline
Old 09-15-2012, 10:28 AM   #9
custom user
Rewards Points: 150
None. Next.
Nope.
JasperST is offline
Old 09-15-2012, 10:41 AM   #10
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Look in box. Where do cables enter? Top or bottom? If top, check outlets in room on second floor above. If bottom, check basement below for wiring going up to box and trace circuit then check boxes before.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline
Old 09-15-2012, 12:24 PM   #11
Good idea. But you haven't found the problem. Where would you look next?
Just like above, good advice, but let's say that you still can't find it?
Nope.
So you would give up and tell the customer to call another electrician?
NECHater is offline
Old 09-15-2012, 12:30 PM   #12
biggles's Avatar
bring an extension cord to the outlet not working the cord has 115 on it right....now use each opening to check for neutral to the cord hot and the cord neutral to the outlet hot....if either is not reading at least you have a direction what side to look at....broken neutral back to the CB panel or loss of hot wire is same reading no 120V
biggles is offline
Old 09-15-2012, 12:48 PM   #13
Ok, so now you MAY know which cable coming into the box is the feed.
I say MAY because you can't be sure that you weren't reading 120V from the hot on the extension cord to the neutral on the DEAD cable because there is a neutral-ground bond down the line. THis type of thing is possible, especially in older houses where 50 handymen have done work.
But let's say you feel confident that you did find the feed cable, what do you do now?
NECHater is offline
Old 09-15-2012, 01:16 PM   #14
An old Tradesmen
Are you asking for a real problem. or just making one up. It sounds like you haven't really checked an anything, and are just saying no to get more responses. Made up scenarios don't work real well. And often come off as trolling.
Old 09-15-2012, 01:26 PM   #15
It's an exercise.
This is the type of thing where not only DIY can learn, but other electrician as well. You're never too old to pickup a new trick that may save you time and money.
Ohhh jeeze
NECHater is offline
Closed Thread
Need some troubleshooting help with light fixture hmp Electrical 1 10-21-2011 04:47 PM
Whirlpool Imperial series gas dryer troubleshooting koz123 Appliances 12 09-20-2011 04:24 PM
Troubleshooting a Projectů. HHEELLLPPP PPPLLEAASEEE! electricbuddy Electrical 4 06-07-2011 11:30 PM
Troubleshooting Maytag Washer Antz000 Appliances 0 03-14-2011 06:52 PM
Help with voltage troubleshooting epicurux Electrical 5 07-02-2007 07:51 AM
