Originally Posted by Lil_lamb
I am also having a problem with mine, I changed the bulb and sensor. I checked and there is power where the sensor plugs in. Still not working. Any suggestions?
Some of the photocell are not designed to handle the flourscent load at all so double check the type of photocell to see if you have two or three wire photocell.
If three wire it should not have any issue with it at all. { unless the photocell stated that can not use with electronic loads }
If two wire then yeah you may got a issue due some of the photosensor will not work with electronic ballast { it will flicker anyway during off mode }
Merci.
Marc
