Troubleshoot Dusk To Dawn Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 07-22-2011, 07:42 AM   #1
troubleshoot dusk to dawn lighting
Recently my dusk to dawn light has failed to turn on. Replaced the 120v 3 prong sensor on top with the arrow facing north as indicated. It turned on for the 1-3 minutes. At dusk, it turned on for that night and has not since. Any suggestions?
frmindiana1 is offline   Reply With Quote
Old 07-22-2011, 07:45 AM   #2
Master Electrician
Rewards Points: 3,698
Have you replaced the lamp?
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
frmindiana1 (07-22-2011)
Old 07-22-2011, 08:41 AM   #3
no, I have just replaced the sensor. If I take the sensor out and put back in it will repeat the cycle I stated earlier and then the next night nothing.
Old 07-23-2011, 12:40 AM   #4
" Euro " electrician
frenchelectrican's Avatar
What voltage this luminaire is wired up for I know majorty of the resdentail Dusk to Dawn unit are useally wired up for 120 volts but few older one may have 240 volt verison did you keep the old photocell somecase they will have a marking on them.
My SOP is always get Multi Voltage photocell due it will cover majorty of them.
Was any light reflecting to the photocell that useally prevent it comming on so you may have to change the postion a little to reduce the glare or reflected light get into photocell.
Merci,
Marc
Old 07-25-2011, 07:21 AM   #5
I did take the old one in to get the exact replacement. But I may try to change position as you stated. thank you
DUSK TO DAWN LIGHT going on for 1/2 hour then off then back on. Jbl15666 Electrical 7 11-14-2010 01:47 AM
Troubleshoot Dusk to Dawn outdoor light marchem Electrical 7 09-05-2010 02:01 AM
Dusk till Dawn Light (Pole Light) Livewire78 Electrical 15 04-13-2010 08:53 AM
Dawn to Dusk Porch Light problem jaw444 Electrical 7 04-20-2009 04:14 PM
dusk to dawn light Pudge565 Electrical 5 09-27-2008 10:53 PM
