Trouble With Wiring New Switch In Old House - Electrical - DIY Chatroom Home Improvement Forum
Old 02-14-2010, 09:22 PM   #1
Trouble with wiring new switch in old house
I have a 1918 house that had a push button switch and next to it was a small dome light that would turn on when the switch was off. The push button switch has gone bad.
There are three wires going into the box. How do I hook these up to a new switch, and what type of switch do I buy?
Thanks for your help!
gjcmemphis is offline   Reply With Quote
Old 02-14-2010, 10:03 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
were all 3 going to old switch? if they each went to a seperate point on switch its a 3 way probably
plummen is offline   Reply With Quote
Old 02-14-2010, 10:27 PM   #3
It's an old style push button switch.
This is how it worked: when you pushed the button on one side, the lights came on. When you pushed it another way, it lit a small bulb light. I get 120 volts on a meter when I connect wire A to wire B and wire C, but nothing when I connect wire B to wire C.
When I hooked the wires to a 3 way, it blew the fuse.
Old 02-14-2010, 11:26 PM   #4
plummen's Avatar
if the bulb is in the switch the 3rd wire is a neutral ,need more details
Old 02-14-2010, 11:35 PM   #5
Learning by Doing
Leah Frances's Avatar
Picture's worth a 1000 words in these sorts of situations - and the folks who really know what they are talking about will look at pics and help you figure it out.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 02-15-2010, 07:46 AM   #6
pics
picture of switch
Old 02-15-2010, 07:47 AM   #7
picture of back of switch
Old 02-15-2010, 09:02 AM   #8
Rewards Points: 1,596
I don't see the pics; just an icon?
bob22 is offline   Reply With Quote
Old 02-15-2010, 10:05 AM   #9
Here is a link to the pictures:
http://pacelinecapital.com/switch.htm
There are three wires in the box
Wire A
Wire B
Wire C
Wire A and B and Wire A and C produce 120 volts
When I connect Wire B and C together, the light still does not come on.
Old 02-15-2010, 05:40 PM   #10
What about voltage between B and C?
Is the box grounded? If so, any voltage between ground and A, B, or C?
Correct wiring diagram for 1 story house jdm001 Electrical 63 06-24-2010 04:35 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Wiring two floodlights to a triple switch chrisjardine12 Electrical 20 01-23-2009 12:29 PM
New wiring and switch for bathroom exhaust fan looking4help75 Electrical 9 06-27-2008 04:15 PM
Cost of replacing old knob ant tube wiring in house bikerboy337 Electrical 3 03-26-2005 08:50 AM
