Trouble with three switches in bathroom
I've run power up to my renovated bathroom and set up three switches to:
1. light 2. fan 3. two lights over mirror It all worked when it was first wired like this, but then the ceiling light kept burning out. I determined that the power source was 240 volt, so I changed that to 120 volt and now it is indicating power but nothing is working yet.... Please help! |
I took the power from a line that runs directly from the panel. It is from a 'pony' panel that was originally used for 240 volt baseboard heating. I disconnected the neutral wire and put it on the bar at the top of the inside of the panel.
I had all the black wires connected to the power source but disconnected the fan and 'mirror' light so that I could isolate the ceiling light. Now, the neutral wires are connected together and the power is pigtailed to the switch. The other black wire connection goes to the ceiling light... |
You originally ran 240V to 3 things that require 120V?
Then you figured that out and now have 120V but your 3 things don't work? It's possible you have ruined your 3 things, especially the motor to the fan. It's also possible you have your 3 things wired wrong. It almost sound like you have your 3 things wired in series. so now your fan, and two sets of lights don't work? do you have 120V to each of these items after you turn each of their switches on? I would test for 120V at each item individually by turning on each switch separately. Do you have 120V at those locations when you do this? |
Ceiling light only
They can't be connected in a series as each has a pigtail to each individual switch.
I've disconnected two of them and have ONLY the ceiling light connected to the power line. What seems odd is that I get a 120v reading even when the switch is in the off position. |
Get yourself a meter and troubleshoot the issue....
Not very helpful. I'm asking the questions because I don't know enough about electrical problems!
Yes, I have power to both the switches and the loads.
Except I didn't have a light on the ceiling, it was just a 'pigtail' light and I'm now using a different one...
I bought a brand new pigtail light and changed the bulb (to ensure it wasn't simply the bulb) and it doesn't work...
Can you help? |
If not, then go to switch, do you have 120 volts at switch box? if so, are you sending 120 volts to light fixture, im guessing you have a bad splice or dont really have 120 volts at switch box... |
Am I the only one thinking this is death waiting to happen???
I think we need pictures of the panel to see what is going on before we try to assist you any further. What you have done so far is deadly dangerous. Please stop until either we or an electrician can assist you. DM |
Bathroom light and switches.
(1). Turn off the power to the house before starting, and identify the branch circuit circuit breaker either in the main or sub-panels: Turn the branch circuit breaker supplying power to the bathroom light too-
(2). Now, take a close look at the filament of the burnt bulb - (if it is incandescent, that is) - If it is broken and dangling from one of the bulb's three internal power posts, then try and swirl it around until the filament catches on the adjacent post from which it hangs. (3). Once this is achieved, gingerly screw the light bulb into the socket, making sure the filament doesn't dislodge, and swing loose again. (4). Turn the bathroom switch to the on position. (Note, nothing will happen, because the power to the house is off at the main panel). (5). Lock the bathroom door. (6). Go to the main panel, and turn on the main power. (7). Now, gently turn on the branch circuit breaker. If you hear a loud explosion coming from the bathroom area, immediately turn off the branch circuit breaker, and put a piece of duct tape over the handle. Write - "Do Not Turn On" on the duct tape, and close the panel door. Never enter the that bathroom again! Build a new one with a sun light in the ceiling and take bathes and showers in the day time. You don't need power in a bathroom...! Remember, electricity and water don't mix.:yes: |
| All times are GMT -4. The time now is 06:00 PM. |
