Trouble With Siemens - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-18-2011, 06:12 PM   #16
jimphilly's Avatar
how else do you cut power to house?
jimphilly is offline   Reply With Quote
Old 05-18-2011, 06:38 PM   #17
Rewards Points: 512
Pulling the meter without the consent of the building authority (per Permit) and with the POCO is illegal. If you have a Permit, then OK.
Old 05-18-2011, 06:41 PM   #18
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
So you have been dealing with this potentially dangerous situation for close to ten days now???
WHY not call in a pro to get this fixed??
Originally Posted by jimphilly View Post
i physically remove the meter.the is no other box.i am installing a new neutral from meter to center.
Just doing this on your own? This is NOT a good idea as the others have stated.
Old 05-18-2011, 07:40 PM   #19
Rewards Points: 512
I installed a new siemens load center and I am getting 175 v on 1 side and 65 v on other side .why?
Learning lesson: Since you have a method of measuring voltage, why not measure everything BEFORE removing the old panel?
Old 05-18-2011, 08:44 PM   #20
Rewards Points: 1,494
the electric company came and said it wasn't a bad neutral so i reinstalled the center.At the lugs it read 120 and 120.When i reconnected the lines they read 180 and 60.I lost a few bulbs..
With no power being used including when the load center has been disconnected completely temporarily, both sides will be 120 volts.
With a neutral problem, as things are turned on and off the voltage will keep changing and seesaw back and forth. The side with more amperes being drawn will go below 120 and the other side will go up.
240 only volt equipment (loads) and circuits are not affected by a neutral proglem.
Are all circuits affected or just a few?
tadem breakers for Siemens type QP AWM Electrical 1 03-12-2011 11:23 AM
Substituting a Murray for Siemens branch breaker mfreeland Electrical 14 12-04-2010 09:04 AM
central air cooling and heating trouble cotton HVAC 2 05-19-2010 07:31 PM
siemens breaker /square d HOM teanne Electrical 4 01-26-2010 08:41 AM
Fire pit build over existing concrete deck - am I headed for trouble? mitchcos Building & Construction 10 04-15-2009 07:26 AM
