Old 07-16-2011, 05:26 PM   #1
Trouble replacing a wall sconce
I am trying to replace a wall sconce. The electrical box is rectangular in a vertical orientation and the holes for the mounting screws are at the top and bottom.
The new sconce has its own custom circular mounting bracket and it doesn't fit the holes in the box. The diagram in the instructions for the sconce show an electrical box with the mounting holes on the corners of the box. I have never seen a box like that.
Is there anything I can do other than return the sconce?
elmonty is offline   Reply With Quote
Old 07-16-2011, 05:33 PM   #2
Licensed electrician
You should be able to try different alignments on the bracket to find a a way to match the holes to the slots.
Old 07-16-2011, 05:36 PM   #3
I have tried that. The mounting bracket has two screws extending from it for mounting the sconce. Those screws must be in a horizontal alignment. there is no way to get both mounting screws into the bracket in a way that matches the holes in the box.
Old 07-16-2011, 05:41 PM   #4
electrician
could you use a unibit and hog one of the holes out and use a washer to hold the bracket on?
tweak is offline   Reply With Quote
The Following User Says Thank You to tweak For This Useful Post:
oh'mike (07-16-2011)
Old 07-17-2011, 07:05 PM   #5
New light fixture boxs are octagon shaped .how ever home depot cares a light fixter adapter bracket wich swivels to fit different boxes most new fixtures i have installed come with this bracket.
wg cahill is offline   Reply With Quote
Tags
fit, mounting, sconce
Replacing Doors in masonry wall mwpiper Project Showcase 17 05-12-2011 08:00 AM
I'm having trouble replacing a wall switch jamesjames Electrical 6 03-14-2010 03:44 AM
Temporary wall support question discojv Building & Construction 7 01-25-2009 08:23 PM
Replacing wall with engineered Beam pinkertonpv Building & Construction 4 01-15-2009 12:18 AM
