Trouble Replacing A Switch / Outlet Receptacle. - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2011, 05:19 PM   #1
Trouble replacing a switch / outlet receptacle.
Help, I am replacing a switch/socket receptacle that broke. Old switch/socket had three terminals, new four. Of the four incoming wires only one combination of two wires show power together. I have tried several different wiring patterns, most blow the fuse, one pattern will give a hot socket and light on, no matter switch position. Thought this would be an easy swap, not so far.
Hey BC is offline   Reply With Quote
Old 05-24-2011, 05:40 PM   #2
Lic Elect/Inspector/CPO
Does it look like this?
Hot goes on brass term feed from switch gooes to term opposite, should be brass or black color.
Neutral goes on silver color on same side as ground up by outlet area.
NJMarine is offline   Reply With Quote
Replacing Toggle Switch with Rocker Switch dogsitter Electrical 8 07-04-2009 05:24 PM
adding outlet from light switch tad Electrical 17 06-05-2009 11:25 PM
Replacing light switch in series wired home - help! kellykate Electrical 6 04-16-2009 06:37 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
