Trouble With Line Side And Load Side Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 09-03-2010, 03:02 AM   #1
trouble with line side and load side wires
We have three transformers 25okva each and connected thru closed delta connection. Our line side have 6 wires of 25omm each in each transformer. Our main breaker is 2500 Amperes. Our wires at load side is 7 wires of 250 in each line. Our actual load is almost 1800 amperes. What do you think is the problem why our wires from main breaker going to basbar are having hot temperature of up to 80. Anybody who can answer me..
lenlen1016 is offline   Reply With Quote
Old 09-03-2010, 03:23 AM   #2
Rewards Points: 1,192
Lack of maintenance.
bobelectric is offline   Reply With Quote
Old 09-03-2010, 07:43 AM   #3
I=E/R
a7ecorsair's Avatar
Posting like this make me wonder what is the purpose. Does this even sound realistic? The OP knows quite a bit about his commercial operation and is worried about the temperature of the breaker (2500 Amps) to buss bar wire which is 250mm or 10" in diameter. I believe this is out of scope for this site
a7ecorsair is offline   Reply With Quote
Old 09-03-2010, 07:49 AM   #4
Just call me Andrew
Rewards Points: 1,020
Andrew
secutanudu is offline   Reply With Quote
Unintended kitchen remodel Itsdanf Project Showcase 191 06-14-2010 11:23 AM
reusing breakers tns1 Electrical 24 08-02-2009 11:43 AM
GFCI question: can line and load wires be run inside the same conduit? thegonagle Electrical 32 04-16-2009 06:07 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 04:48 PM
Load vs. line wire gvernea Electrical 5 01-16-2008 12:50 AM
