Trouble With Lighting Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 01-27-2012, 01:07 PM   #1
Trouble with lighting circuit
I have 4 light circuits on a 15 amp breaker in my laundry room/carport. My carport light we keep on 24/7 for security and use a florocarbon bulb. Trouble is, it burns out frequently. Also, one of my lights inside, a flourescent light, works off and on.
Could there be something wrong with the wiring connections to cause that to happen?
Thanks.
GPerry12345 is offline   Reply With Quote
Old 01-27-2012, 01:23 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Maybe start by checking voltages and checking for loose connections.
rrolleston is offline   Reply With Quote
The Following User Says Thank You to rrolleston For This Useful Post:
plummen (01-28-2012)
Old 01-27-2012, 05:44 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,100
If any lights are not working correcttily ?
Then yes you have a problem !
Most likely cause is a loose/dirty connection !
Start at the problem light and work backwards
checking all connections, dont forget to check the
switchs also, a dirty contact in the switch can also cause
you problems !
P.S. What is a florocarbon bulb ?
Is it a CFL ?
dmxtothemax is offline   Reply With Quote
Old 01-27-2012, 07:34 PM   #4
Rewards Points: 240
Is the CFL bulb in the carport in an enclosed fixture? If so, that's why they keep burning out. Enclosed fixtures trap the heat, and those CFLs with their cheap Chinese capacitors can't take any heat buildup.
As for the fluorescent fixture that sometimes works and sometimes doesn't, it could be several things. It may not be properly grounded. Or it may need a new tube, a new ballast, or (if it's an old fixture) a new starter.
fa_f3_20 is offline   Reply With Quote
Old 01-27-2012, 09:07 PM   #5
Both are something I have thought of. I changed the florescent fixture recently after the previous two experienced the same problems. Will check the ground though. With the outside light, it has a glass shroud but its completely open at the bottom. Heat could be an issue in the summers as its hot here (Tucson, Arizona) but just changed one today and its been in the mid 60's for weeks for a high.
I forgot to mention that I also have a ceiling fan powered from the same circuit but none of that would add up to 1440 watts even if all were on at once.
My wife is bugging me that something must be wrong with the wiring but I really am skeptical that to be the case. The two inside overhead light sockets with florocarbon bulbs don't burn out frequently but the outside one does. We leave the outside one on for security mostly 24/7. I wonder if that might be an issue?
Old 01-27-2012, 09:10 PM   #6
Flourocarbon in my vernacular meant CFL
Old 01-28-2012, 12:23 AM   #7
" Euro " electrician
frenchelectrican's Avatar
Is your outdoor luminaire is enclosed ? if so some of the CFL screw in bulbs can not work with enclosed luminarie due the heat will kill the electronic ballast.
Second thing if you have MWBC ( Multi Wire Branch Circuit ) you will have to check the connection espcally with netural connection that will be first thing can cause a mess if not done right.
Merci,
Marc
Old 01-28-2012, 10:43 AM   #8
Rewards Points: 115
is your outdoor light on a photo cell? cfl's do not last long with these.
pokey is offline   Reply With Quote
Adding outlets to existing 15A lighting circuit rstain Electrical 3 12-03-2011 11:30 AM
20 amp lighting circuit trosenda Electrical 4 01-04-2010 01:26 PM
Circuit advice for finishing basement Straightgrain Electrical 16 03-25-2009 10:07 AM
Recessed lighting for 15 amp circuit jacads Electrical 5 03-12-2009 01:12 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
