Old 12-28-2008, 04:47 PM   #1
Trouble with install of light fixture
I am in the process of replacing a florescence fixture (which broke physically) with a regular 2 light bulb fixture. When I installed the new light, it doesn’t work. The circuit that it is on has 2 switches on it. When I measure across the black and white wires, I get roughly half the voltage when switched on, no voltage when off. Any ideas on where to start looking?
cmonsterjr is offline   Reply With Quote
Old 12-28-2008, 04:58 PM   #2
My License Ain't 4 Sale..
Describe the wires you have in the light box now and how they are connected. Did you wire the new light exactly like the old one?
Old 12-28-2008, 05:02 PM   #3
I used the same set of wires as the old one. The black set has 3 wires jumped together using a wire nut (this is where the original black was) and the white is a single stand alone.
Old 12-28-2008, 05:42 PM   #4
Ok. What are the other white wires doing? Is it possible for you to snap a pic and post it here?
Old 12-28-2008, 06:57 PM   #5
dSilanskas's Avatar
Sounds like you lost your neutral somewhere.
dSilanskas is offline   Reply With Quote
Old 12-28-2008, 08:06 PM   #6
joed's Avatar
Sounds like you might be switching the neutral which is wrong.
Are you sure the white wire wasn't with the other whites and the black connected to the single white wire?
Recessed Light Install Question kennykenny Electrical 2 12-03-2008 11:00 AM
Hall light worked before installing a new light fixture in bathroom jcfan7 Electrical 40 02-23-2008 10:46 AM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
Replacing Bathroom Light Fixture shapeshifter Electrical 1 02-05-2007 05:33 PM
light fixture box set below plaster. ERIK2173 Electrical 9 10-20-2005 07:33 AM
