Trouble Inserting Recessed Light Into Ceiling Cavity - Electrical - DIY Chatroom Home Improvement Forum
Old 11-01-2009, 05:14 PM   #1
I am changing the existing recessed light fixtures in my kitchen. I've taken one of my fixtures down already, and I have wired the new fixture. But my problem is I'm not able to fit in my new fixture into the hole. The hole is 3 7/8th inch, so that is the size my new (and old) can is. For the life of me, I'm not able to fit in the hole. My new light fixture looks like this:
http://www.lightingexperts.ca/compon...e241be4cfe.png
My old light fixture had the wires connected with an armoured cable, so it was flexible, and this is less so. I can't find anything on the internet with the answer to this question. I really hope someone here can help. I'm getting sooo frustrated.
Thanks!
PotLightGirl is offline   Reply With Quote
Old 11-01-2009, 06:54 PM   #2
Electrician
Rewards Points: 760
Do you mean the can won't go up into the ceiling, if so why not trim the hole a little for it slides in.
Or are you haveing a different problem that i am not grasping.
darren is offline   Reply With Quote
Old 11-01-2009, 08:48 PM   #3
Residential Contractor
Recessed can lights, if they are truly remodel cans usually have a template so you are able to cut the correct sized hole. Compare that with the existing hole.
rselectric1 is offline   Reply With Quote
Old 11-01-2009, 09:00 PM   #4
Thumbs up
Most likely the OP did NOT buy "Remodel"/ "Old Work" fixtures. Or the diameter of the New "Can" is different! Eliminate confusion Through Education! (Separate Message) Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 11-01-2009, 10:31 PM   #5
Child Alert! Pull Up!
fltdek's Avatar
fltdek is offline   Reply With Quote
Old 11-01-2009, 10:39 PM   #6
fltdek's Avatar
I didn't post the install instructions to be smart, just found them searching on line....
These are suitable for any application, just not understanding whats preventing you from putting it through the hole? Is your home a two story? If so could the be a floor joist too close to the hole or something else obstructing? Is the cable (existing) clamped to a floor joist making it difficult to push the junction box (mounted to can) into place? May have to just stick your hand up in there and feel around to see whats going on.
Can you provide any more clarification on the matter?
Old 11-02-2009, 11:19 AM   #7
Rewards Points: 1,418
You might be able to dismantle the fixture and play "build a ship in a bottle".
You might be able to purchase (separately) wider trim rings so if you had to trim the hole bigger, it would be easier to cover up the edges.
Old 11-02-2009, 02:15 PM   #8
fltdek's Avatar
You might be able to purchase (separately) wider trim rings so if you had to trim the hole bigger, it would be easier to cover up the edges.[/quote]
More than likely your not going to be able to get a wider trim for that particular fixture, judging by the bulb (GU-10) I am fairly sure its a low-volt. fixture, maybe not but...anyhow, unless you purchase the cans separately with the options of diff trims - usually whole kit lights are what they are not many options for them..
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 08:06 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
