Old 10-02-2012, 09:48 PM   #1
Trouble with fluorescents
Hi, new to the site! Just wanted to pick the brain of the pro's out there. I have two radionic fixtures four t12 bulbs each with two ballist each. They both stopped working at the sametime, so i started by checking power up to the fixtures. I am getting a hot signal from my hot stick when the three way switch is in the correct position up to all four ballist. I also am getting a hot signal on the wires leaving the ballists. I checked all the connections thinking I might have lost a nuetral, and they are all good. I'm not sure what else to check besides just replacing bulbs and hoping im overlooking something. Any suggestions?
Thanks,
WeekendGI51
WeekendGI51 is offline   Reply With Quote
Old 10-02-2012, 10:22 PM   #2
First thing I would check is the voltage from hot to neutral. You should have ~120V. The lamps, all the connections, ballasts, and tombstones could also be the problem, but if you have 2 separate fixtures with separate ballasts and everything then I would look and make sure you have the proper voltage coming in.
I find many "pen style" non contact testers have poor accuracy.
AltaSparky is offline   Reply With Quote
Old 10-05-2012, 05:29 PM   #3
Rapid start?
A solenoid tester or an analog VOM work better to test voltage in these situations.
You lost both at once so the ballasts and bulbs are good. You lost power or maybe ground. If the neutral and hot check out, test the ground. Some fluorescent ballast/bulb combos will not strike unless the case ground is good.
ionized is offline   Reply With Quote
Welder Trouble BuB901 Electrical 4 05-25-2012 02:39 PM
How should I trouble shoot a blower motor jse HVAC 2 11-08-2011 10:10 PM
Fire pit build over existing concrete deck - am I headed for trouble? mitchcos Building & Construction 10 04-15-2009 08:26 AM
Just enough knowledge to get into trouble captain25 Introductions 1 03-23-2009 02:30 PM
Carrier Infinity 96 Trouble Code 25 travissmith25 HVAC 1 02-16-2009 12:35 PM
