Trouble Adding A New Phone Jack - Electrical - DIY Chatroom Home Improvement Forum
Old 04-26-2010, 02:28 AM   #1
Trouble adding a new phone jack
Apologies if this is the wrong forum.
I am trying to add a new phone jack in my living room, and I am having some serious problems. The house it a bit old, so the original wiring looks like cat3 (4 wires, Red/Green/Yellow/Blue), but it is a lot thicker than regular cat3, and is not twisted.
I went searching for this wire, but was unable to find it, so I just bought some cat3 cable from my local hardware store (not twisted). I traced the phone lines to the origin, and noticed that only 2 of the wires are being used (Red/Green), so I stripped my cat3 cable down, and attached two wires to the same spots where everything else is attached.
I then ran the wire to my living room (about 50 feet), and have tried to copy what my phone jacks inside the house look like, but I can't seem to get a dial tone. The kicker is that my DSL works (although the is only running at about 30% and goes in and out).
The two connected wires (Red/Green) are in the center (pins 2 & 3), and the other two pins are just wired from the terminal (Black/Yellow) on the jack to the pin (1 & 4).
I have tried every possible combination, but I have had no luck. I was wondering if anyone had any ideas.
Did I buy the wrong wire? I couldn't find the thick wire anywhere.
gmoniey is offline   Reply With Quote
Old 04-26-2010, 02:40 AM   #2
only thing that comes to mind is wire length have you tried just using a short piece to the jack first?im no expert hopefully someone else will chime in
kennzz05 is offline   Reply With Quote
Old 04-26-2010, 04:54 AM   #3
DIY staff
Rewards Points: 7,174
Get your self an old phone and two alligator clips--hook the clips onto the red and green wires on the phone cord---now you have a line tester---that should help.
The problem could be as simple as a bad jack---or a faulty wire or lousy connection---Mike--
Old 04-26-2010, 05:06 AM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
T0 understand the telephone wire colors here is a chart
http://nps-vip.net/tester/colortbl.htm
To trace for the presence and polarity of a signal I use:
http://www.amazon.com/Leviton-830-C2...2274963&sr=8-1
Another Telephoe line Tester from HD:
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
or a similar type tester from LOWE'S, or many Hardware Stores:
http://doitbest.com/Electrical+tools...sku-563226.dib
or
http://www.acehardware.com/product/i...Id=47846997173
All of these (less than $10) testers use a similar LED Diode test circuit, so I don't think any one model is better than another.
Let us know what happens.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-26-2010, 05:36 AM   #5
DIY staff
If you have ATT With a 'shared' dsl/phone line you may have it wired right already---and simply need one of those plug in signal splitters---See if you have a little plug in gizmo on another working phone line.
---Mike--
Installing a new phone jack. Which wiring to use for only 6ft? Help! romo218 Electrical 18 10-03-2009 10:20 PM
Installing a new phone jack. Which wiring to use for only 6ft? Help! romo218 General DIY Discussions 2 06-17-2009 04:56 PM
Phone Jack Hookup Problem kennykenny Electrical 18 12-07-2007 03:48 PM
Electrical outlet phone jack extension? mikehende Electrical 3 11-28-2007 08:05 PM
New Phone Jack Install - Q & A 101 allen1466 Electrical 7 07-17-2007 11:46 PM
