Tripping GFCI Beaker - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2013, 07:41 AM   #1
Rewards Points: 87
I have my pool wired with #12 wire and 20 amp GFCI breaker. When I turn on the GFCI breaker sometimes it will trip. Most of the times it will work properly. The pool is straight wired so the motor will come on immediately. The pump motor is 220 and rated 5.9 amps. It is a VS magnetic motor.
Sometimes when I turn it on and it immediately trips, I can cut the breaker off and right back on and it works fine.
Is the breaker probably bad. I have bought a new one but would like to know before I replace it.
TGMcCallie is offline   Reply With Quote
Old 06-30-2013, 08:14 AM   #2
Rewards Points: 446
Electricity, combined with water, protected by a GFCI that is tripping from time to time.
There is the poster child of why GFCI's were invented and why they've saved so many lives.
Always trust safety devices (your GFCI in this case) to be indicating that something is wrong that needs to be investigated and repaired before someone is hurt or worse.
You need to have the entire pool circuit checked for the reason the breaker is sensing a potential deadly condition.
old_squid is offline   Reply With Quote
Old 06-30-2013, 09:25 AM   #3
Master Electrician
Rewards Points: 3,818
A 240 volt motor requires a 2 pole 240 volt GFCI breaker.
brric is online now   Reply With Quote
Old 07-03-2013, 08:07 PM   #4
Rewards Points: 87
Problem solved.
The GFCI breaker was weak. I replaced it with a new one and everything works correctly as should.
Old 07-03-2013, 09:19 PM   #5
Rewards Points: 85
Originally Posted by TGMcCallie
Problem solved.
TGM- I hope you did solve your prob but like many I ask you to have someone to come in and check it out. It's worth the service call bro! Be safe and enjoy your pool!
JohnC20 is offline   Reply With Quote
Old 07-03-2013, 09:27 PM   #6
Rewards Points: 87
I did seek professional help. My neighbor owns his own electrical company which is older than I am (I am 76). He did not look at it but said it sounded like the gfci was bad due to excessive tripping and age.
He said to purchase another breaker and install it. If it then does not
work properly he would come and check it out for me.
I did as he advised and it has not tripped the gfci in 4 days so I figure he
was correct in what he advised me to do.
Thanks for everyone's advise.
Old 07-04-2013, 09:10 AM   #7
Rewards Points: 150
Do not use the breaker as a switch to turn the motor on and off it will greatly extend the life of the breaker.
RIP EJT
usair is offline   Reply With Quote
Old 07-04-2013, 09:24 AM   #8
Rewards Points: 85
Ok! Just looking out for ya!
Old 07-04-2013, 09:26 AM   #9
Rewards Points: 236
i was thinking that. while it can work as a switch. its not a switch.
Fix'n it is offline   Reply With Quote
Old 07-04-2013, 03:12 PM   #10
Rewards Points: 87
I guess that was what weakened he GFi breaker. I would rather cut if off sometimes from the garage rather than at the pump especially when it was raining. I will no longer do that. I will instead just let the digital timer cut it on and off.
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
Trouble with GFCI tripping - first time electrical ryan112ryan Electrical 8 07-05-2012 08:16 AM
Garage GFCI keeps tripping faromic Electrical 7 08-30-2011 10:45 PM
Pond pumps tripping GFCI lendosky Electrical 23 12-23-2010 03:22 PM
Random GFCI tripping, Data Rack theatretch85 Electrical 5 07-10-2009 08:20 PM
