Old 11-15-2007, 08:53 AM   #1
Tripped fuse - but has it broken my light Switch?
Hi all,
Just bought my first house and been trying to do as much as I can, including fitting the odd light ceiling fitting. When I wired it up and turned the power on, it tripped my fuse for the downstairs lights. Fair enough, I checked my work and found I have made a wiring error, but when the fuse tripped it has affected the switch that turns on the light. It's a switch thats been in the house for a while and its a Crabtree chrome switch from B&Q. It will not physcially return to the off position, its like there is something there stopping it.
The wiring is now correct and when I turned the power on, the light is on (due to the swtich being stuck in the on position). Can anyone tell me whether this is some kind of safety device on the light switch, what is is that is blocking me turning it off and whether it is fixable?
Many thanks for your help in advance - I am stuck (with a light on)!
Andy
themanmathias is offline   Reply With Quote
Old 11-15-2007, 10:59 AM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Just change the switch with a like one... be it 3-way switch or a normal single pole light switch. Most likely the massive fault current passing through the switch when you made your wiring error tripping the breaker welded the contacts in the on position.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
New light switch burns out dsbutler71 Electrical 12 09-05-2007 08:34 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Light switch not working! jtbel Electrical 4 12-09-2006 07:34 PM
Wiring a light with switch....please help!! lindo1951 Electrical 19 10-16-2006 03:32 PM
Red & Black wire from light = blown fuse leedslad Electrical 3 08-28-2006 07:54 PM
