Tripped Circuit Breaker Removing Fan.. - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2012, 10:54 AM   #1
tripped circuit breaker removing fan..
im hoping not to sound like an idiot.
i was removing the fan to replace it with a new one. i did not turn off the
breaker, but instead turned off the 2 switches on the wall that controlled the fan and the light. as i disconnected the wires and removed the metal bracket that is bolted to the box in the ceiling, the neutral wire touched the copper wire, and tripped the circuit. I reset the breaker and checked for voltage with all 3 wires disconnected at the fan connection. no power present anywhere thats measurable....my dad says something is screwed up, boss says it is ok and thats what will sometimes happen depending on how the circuit is wired. what do i do? would rather not cause a fire. thanks! chris
chris177 is offline   Reply With Quote
Old 09-10-2012, 10:59 AM   #2
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
Who is your boss and how can he make that statement?
JulieMor is offline   Reply With Quote
Old 09-10-2012, 11:06 AM   #3
apprently someone that does not know what is going on? where do i start to find the problem?
Old 09-10-2012, 11:17 AM   #4
Licensed Pro
AFCI breaker? Neutral-ground contact will trip these.
Old 09-10-2012, 11:43 AM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
Yep, even with the switch off, the arcfault breaker will trip with a neutral ground connection.
Old 09-10-2012, 11:55 AM   #6
sounds like the hot was fed to the fan first and the down to the switch box.
The Following User Says Thank You to DannyT For This Useful Post:
Julius793 (09-10-2012)
Old 09-10-2012, 12:05 PM   #7
i will have to check my connections and the breaker on my lunch break. i disconnected the wiring and connected the fan wires directly to the feed with no switches in line and then touched the white wire to ground and it still tripped the breaker. thanks for all your help.
chris
Subpanel Circuit Hot With Breaker Tripped diyjunkie Electrical 11 08-25-2011 11:43 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
900W and up trips breaker, Circuit draws power even with everything off... jasonblu Electrical 40 12-09-2009 03:29 PM
Switch triggering GFCI breaker on a DIFFERENT circuit stillmarried Electrical 5 11-29-2009 10:14 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
