Tripped Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 08-11-2013, 07:12 PM   #1
Rewards Points: 260
Tripped Circuit
Hi all. I have a tripped circuit on my electrical panel. It's just stuck in the off position and when I try to push it back over to on, it doesn't stay. It just goes back to off. How can I fix this? Thanks.
Jesse
jpearson311 is offline   Reply With Quote
Old 08-11-2013, 07:20 PM   #2
Licensed electrician
Rewards Points: 1,630
Many breakers need to be turned fully off and then on.
Old 08-11-2013, 07:23 PM   #3
Rewards Points: 13,740
What does that circuit control?
If shutting it all the way off and back on does not work you may have a dead short.
DO not keep trying it, find what what shorted.
Old 08-11-2013, 08:33 PM   #4
Rewards Points: 6,652
Bad breaker would be my first guess. Pull the breaker out of the panel, with the wire disconnected from it, and see if you can cycle it from off to on. If it doesn't, then it is shot and you need to replace the breaker.
Nothing more simple. If it is a dead short, it would allow you to cycle the breaker, but as soon as you go to on position, it would go back off, or throw sparks when you attempt to go to on.
Old 08-11-2013, 09:10 PM   #5
Electrical Enthusiast
Rewards Points: 504
This may sound silly, but are you sure you turned it all the way off? Some breakers have to be pushed firmly in the other direction (called "extreme off") before they will reset. What brand of breakers are these?
Otherwise you have a dead short somewhere that needs to be replaced, or a faulty breaker.
Kyle_in_rure is offline   Reply With Quote
Old 08-15-2013, 01:20 PM   #6
Rewards Points: 260
Thanks for the replies guys, but it looks like the wiring for that entire circuit is bad. My electrician is going to rebuild it next week. Ugh...
Jesse
Old 08-15-2013, 01:40 PM   #7
Jesse
What do you mean by the wiring on the circuit is bad? Did you have a really bad short, that it burnt up the wiring, or critters in the house, that chewed apart the line in various places?
Old 08-15-2013, 01:42 PM   #8
Rewards Points: 260
No the majority of the circuit is constructed from knob and tube because my house is so old. Some of the insulation has worn off the wiring and it's kind of a mish mash of knob and tube and romex. That's all.
Jesse
The Following 2 Users Say Thank You to jpearson311 For This Useful Post:
gregzoll (08-15-2013), Kyle_in_rure (08-15-2013)
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
Several outlets and lights on a circuit are not functioning, while others are fine. mrdojo Electrical 12 03-26-2012 06:23 PM
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 06:09 AM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
