Triplex Outlets - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-11-2008, 06:57 PM   #16
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Originally Posted by MdangermouseM View Post
would a single outlet/switch combo help?
DM
My a outlet / switch combo, if that is what I am thinking of with a 1 outlet, and a 1 switch together, then that would be pretty weird for all my regular outlets to be setup like that, and I don't see why anyone would install a setup like that for there regular wall outlets.
Maybe I missed something?
Jamie
jamiedolan is offline   Reply With Quote
Old 10-11-2008, 06:58 PM   #17
Electrician
Originally Posted by nap View Post
there is no requirement in any code I have dealt with that required up or down but if you notice, all the writing on the recep is right side up when the ground is up.
chris75 is offline   Reply With Quote
Old 10-11-2008, 07:02 PM   #18
DIY'er
jamiedolan's Avatar
My grounds are up on at least some of the outlets that are installed in my house. (too tired / lazy to go look at all of them right now)
I am pretty sure that in the product into sheet for leviton that the grounds were up in the photos.
Do the inspectors like it one way or another, or is this just another one of those age old debates type of things that people fuss over for no good reason?
Jamie
Old 10-11-2008, 07:09 PM   #19
Rewards Points: 2,350
Originally Posted by jamiedolan View Post
All single boxes, flush up to the wall.
How do I find out of a outlet is self grounding? I have a Pass & Seymour Legand Premium Sitting here I bought today. It says "Outlet; Decorator Grounding"
Jamie
One of the attachment screws will pass through a brass clip. Like in this pic.
Old 10-11-2008, 07:22 PM   #20
Electrical Contractor
kbsparky's Avatar
Originally Posted by chris75 View Post
... refer to NEC BS110.3...
As stipulated in your image, that is a bunch of "BS" ....
Old 10-11-2008, 07:26 PM   #21
Electrician
Rewards Points: 800
okay stop the argument and reread my post, it was a joke.
darren is online now   Reply With Quote
Old 10-11-2008, 07:27 PM   #22
DIY'er
jamiedolan's Avatar
So would this outlet be considered ungrounded? This is an original installed kitchen outlet.
I don't see a brass clip...
Jamie
Old 10-11-2008, 07:30 PM   #23
kbsparky's Avatar
...I don't see a brass clip...
You don't need a brass clip if there is a grounding pigtail attached to the outlet.
Some older installations relied soley on the mounting screws without the clip. Newer codes require either the pigtail, or clip, but do not require both.
Last edited by kbsparky; 10-11-2008 at 07:33 PM. Reason: Picture fuzzy --- looked like a groundpigtail there
Old 10-11-2008, 07:40 PM   #24
Yes, that would be considered ungrounded. You see that hole in the back of the box on the right? That would be the ideal place to attach the grounding conductor. The place it is currently attached is on the cable clamp, not to mention that it is wrapped poorly around the screw. You might consider taking that loose (while the circuit is off, Mr. "I work on it hot"), then using a piece of bare #12, wirenut it to the grounds, then wrap it around a screw in the aforementioned hole, then carry it on to the receptacle.
Old 10-11-2008, 07:42 PM   #25
DIY'er
jamiedolan's Avatar
Nope they didn't pig tail the ground, I agree my photo is deceptive.
So if this were your home, would you pull this out, pig tail the ground, reattached it to the box, and attach one pigtail to the outlet? (or replace the outlet with one that has a brass clip on it)
Do only the really expensive outlets have the self ground clip? ($10+ industrial / commercial / hospital outlets?)
Jamie
Old 10-11-2008, 07:54 PM   #26
Jamie
They are more expensive, yes, but the cheapest isn't that much. But, I would pigtail. I have never relied on the self-grounding clip.
Old 10-12-2008, 12:14 AM   #27
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Jamie
hospital grade receps are up around that price but there are commercial grade receps around $2 or so, including self grounding type.
I too prefer a pigtail.
Old 10-12-2008, 12:17 AM   #28
nap
You talking to me?
nap's Avatar
Jamie
I was considering suggesting replacing the mud rings with 2 gang and install 2 duplex receps but since they are single gang boxes...
Old 10-12-2008, 08:09 PM   #29
DIY'er
jamiedolan's Avatar
Well I didn't really want to, but I got a good deal on the outlets, so I am going to have to do pig tails for all my outlets.
I ordered the Pass and Seymour Legrand Premium Grounded outlets today. 70 of them. @ $2 each. I compared them to the leviton in the $2-$4 price range and felt like the P&S had a little better grip on the plug.
My local hardware store normally wants something like $4.79 each for these things.
I think the old cover plates will still fit, I will have to test it and see. I guess the new ones are cheap enough, but 70 of them. I have a couple outlets less than that, but plan to add a few in the kitchen.
Jamie
Old 10-12-2008, 08:37 PM   #30
kbsparky's Avatar
Most of your "premium" outlets are self-grounding. Look for the tab on the mounting screws before you go to the trouble of installing all those pig tails.
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
GFCI switch to control outside outlets billgeo Electrical 14 09-08-2008 11:09 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
GFI outlets and power ? CALDWELLAPARTMENTS Electrical 3 07-24-2008 05:32 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
