Tried replacing doorbell....now it doesn't work.
Do you have a crawl space underneath your house? Sometimes they are installed there, good luck finding the transformer. Definately sounds like the transformer went bad since touching the wires together does nothing. If worse comes to worse you can always buy a remote battery powered doorbell kit. The chime is powered off a 9volt battery I believe, although you might not be able to get a doorbell that lights up. Best of luck
Oh by the way did you get a new chime kit with the new doorbell?
Reason: clarification
