Tricking The Outlet Tester? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-13-2013, 11:07 AM   #1
Rewards Points: 77
Tricking the outlet tester?
Suspicious of a single three prong outlet in a room of ungrounded outlets, I plugged in my outlet tester and got a two yellow light "correct". Pulled the cover and found the neutral white looped over the green screw. I converted the plug back to two prong.
Is there a different type of circuit tester that will see this if it is wrong?
Now I don't kow whether to trust this one or not...
Doing things almost the right way...
Double is offline   Reply With Quote
Old 02-13-2013, 11:31 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
Nope.
I have never seen a plug in tester that could detect a bootleg ground.
Old 02-13-2013, 12:21 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,942
I'm not aware of any method of detecting a bootleg ground, even theoretically. The trouble is that since ground and neutral go to the same place in the panel, these two configurations are electrically identical - unless something goes wrong. If something goes wrong (a loose or broken neutral), the bootleg ground is way worse than no ground at all.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 02-13-2013, 12:26 PM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Ideal makes a tester called a Sure Test Circuit Analyzer found here. I used one while inspecting in Camden all the time. It also checks voltage and current drop.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
Stubbie (02-13-2013)
Rewire a switch that controls an outlet. z00ropa Electrical 8 10-23-2012 06:00 PM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
Outlet not working, reading "open ground" syren Electrical 3 04-19-2010 04:20 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
