Old 08-30-2011, 10:39 AM   #1
dazed 'n confused
watts up?'s Avatar
Question
Tricking out the JEWEL colors on old-fashioned (toggle) electrical light switches
Howdy. I'm exploring ways of giving illuminated & pilot-light switches a sex change — specifically, taking (any) PILOT light switch and changing it to an ILLUMINATED OFF switch. For the uninitiated, "ILLUMINATED OFF" means that the switch glows when OFF, and "PILOT" means that the switch glows when it is ON.
Leviton, Bryant etc. make red PILOT SWITCHES . . . but I need them to do exactly the opposite: function as red night lights when OFF.
I see only two ways of doing this but I'd be open to any more suggestions:
1) rewire the actual innards of the switch — give it a sex change; or
2) replace the jewel on an already-available ILLUMINATED OFF switch from (for example) IVORY to RED.
I've had these lousy "Decorator" light switches — the rectangular-shaped ones — for years and I hate them, so I'm going back to toggles.
But I sure would like to refit these to my own specifications. Any help appreciated. Thanks guys.
wu
watts up? is offline   Reply With Quote
Old 08-30-2011, 12:53 PM   #2
The switch must have 3 terminals (excluding the green ground screw): raw (unswitched) hot, switched hot, and neutral.
A: With neutral in the switch box. Wire up the pilot light switch normally except put the raw hot on the switched hot switch terminal and the light fixture hot on the raw hot switch terminal. The switch light will be on all of the time.
B: With no neutral in the switch box:
1. You may not dissect the switch and make changes; this will invalidate the Underwriters Labs or other certification and the switch will no longer meet code.
2. The power draw of the pilot light must be small enough so the pilot light works in series with the regular light (light being controlled) and the latter does not flicker.
Connect the neutral and unswitched hot switch terminals together (externally using pigtails) and connect this to the power feed hot.
Note that a switch with a white or clear jewel may not give enough light for use as a night light when fitted with a red jewel.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
The Following User Says Thank You to AllanJ For This Useful Post:
watts up? (08-31-2011)
Old 08-30-2011, 12:57 PM   #3
Originally Posted by AllanJ View Post
Connect the neutral and unswitched hot terminals together (externally using pigtails) and connect this to the power feed hot. Omit connecting the neutral of the power feed cable/wires to the switch.
I said PARDON?? Not sure what you're getting at here. DON'T do this.
CheapCharlie is offline   Reply With Quote
The Following User Says Thank You to CheapCharlie For This Useful Post:
Old 08-30-2011, 02:38 PM   #4
The switch terminals only. Not the incoming wires.
This connects one lead of the switch light (pilot light switch) to raw hot (and one side of the switch) and the other lead of the switch light was already connected to the switched hot (other side of the switch). Then the switch light will be in the circuit when the switch is "off" and be excluded from the circuit when the switch is "on". (Same as an "illuminated" switch.)
Do not connect either hot or neutral wires to a (should be green) ground screw.
Old 08-30-2011, 03:02 PM   #5
gotcha. Connect the screw terminals together....not the wires....lol
Old 08-31-2011, 09:07 AM   #6
dazed 'n confused
watts up?'s Avatar
So you can do this by a simple wire swap? SuWEET. Not being an electrician I wasn't sure just how accessible the wiring inside these switches is. Thanks guys. I'm printing out the entire thread heh heh.
wu
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Light switches not working marc633 Electrical 7 07-22-2008 06:34 PM
3 switches 1 light. need 2 lights 2 switches. Im desprete s richards Electrical 6 07-19-2008 04:18 PM
2 switches to same light use 1 for another light gmcclel Electrical 9 05-29-2007 02:30 AM
Where to buy paddle light switches in bulk? Proulx06 Electrical 3 05-21-2007 07:43 AM
