Tree Lights - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-28-2013, 06:22 PM   #16
Originally Posted by dmxtothemax View Post
For a temporary arrangement, I would be using flexable conduit,
Are you wanting to put cables under ground or flown thru tree's.
UF cable underground. 12in deep GFCI breaker.
Conduit loosely nailed to tree for sleeving...see original post...
CanIDoIt? is offline   Reply With Quote
Old 08-29-2013, 06:01 AM   #17
I can always split the circuit into 2 for lighting moods...
Or put it on dimmers?
oberkc is offline   Reply With Quote
Old 08-29-2013, 09:48 AM   #18
Oso954's Avatar
Rewards Points: 1,108
The lights he linked to, should not be used with dimmers.
Oso954 is online now   Reply With Quote
Old 08-29-2013, 12:43 PM   #19
Good catch! Yes, the fixtures/lamps would have to be dimmable.
Old 08-30-2013, 01:32 PM   #20
Alrighty all. I picked up my 500ft roll of 14/2 UF cable, my 15a breaker, a GFCI outlet (it was cheaper than the breaker, just run it off the load side) and some 1/2" conduit and boxes. Going to do the install soon. I will post pics.
My local store did not have any of the floods left, and after reading some bad reviews, I'm kinda glad I didn't buy them yet.
So I'm buying 3 of these mercury vapor lights. I know if I install these, I'll never have to look at them again for a while. I remember seeing old merc. lights working year after year reliably with them old solid magnetic ballasts. I'm not looking for energy savings, I just want to put them up and not have to look at them again for a long time A lot of the fluorescent electronic stuff never lasts as long as it should, and your replacing it sooner than usual...
http://www.amazon.com/Heath-Zenith-S...+light+fixture
Old 08-30-2013, 02:25 PM   #21
Semi-Pro Electro-Geek
Rewards Points: 2,938
You sure you want those lights? Mercury vapor was phased out years ago due to low efficiency. It also has bad color rendering that makes people look dead. Metal halide is way more efficient and has better color. The fixtures are about the same price. It's getting hard to find mercury vapor lamps anymore, too.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 08-30-2013, 02:35 PM   #22
I originally looked for some 50w MH lights, but there aren't any under $50. Cheapest I've found is $67 each on eBay.
Old 08-30-2013, 03:10 PM   #23
Oso954's Avatar
I'm wondering how you intend to pull 300 feet of 14/2 w/g UF cable thru 1/2 inch conduit ?
You must be a glutton for punishment.
Even with gallons of pulling lube, it won't be easy.
Old 08-30-2013, 03:42 PM   #24
The conduit is just for sleeving above ground up into the boxes.
No way in hell would I try to pull UF completely through 1/2" conduit. It is being directly buried...12" deep GFCI protected
Old 08-30-2013, 05:04 PM   #25
If you look at cost per lumen, rather than per watt, you'll find that the MH is probably cheaper, or at least very close. It's certainly cheaper if you consider power costs. That 100W mercury fixture will produce about as much light as a 75W MH fixture. The mercury fixture is so cheap because they can't be legally imported or manufactured for sale in the US anymore.
Old 08-30-2013, 06:06 PM   #26
Oso954's Avatar
I think there is already a ban enacted on the lamps (bulbs). None to be manufactured or imported after 1/1/16.
Replacing existing recessed soffit lights miamicuse Electrical 35 06-22-2013 07:52 AM
Two light switches in-line to lights? bobgodd Electrical 150 06-06-2013 09:53 AM
Basic question about adding more lights. roasted Electrical 2 04-27-2013 10:31 PM
Lights on one circuit flicker now after tripping breaker shootmenow Electrical 8 04-13-2013 10:44 PM
New lights in basement CooperChloe Electrical 11 01-11-2009 11:22 AM
