Treadmill Popping GFI - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-20-2011, 06:52 AM   #16
If the "tool geek's" idea of using an isolation transformer does not work I will look into hiring an electrician to run a dedicated circuit. If I need to do that I have it ran with 12 gauge and add a 20 amp GFCI breaker. JUst not sure how they will get it to the 2nd floor bedroom. I'm sure there is a way. The garage and breaker box is below which helps.
GD Lee is offline   Reply With Quote
Old 03-20-2011, 09:31 AM   #17
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
GD, A Power Isolation Transformer able to drive your treadmill would be big bucks.
But then pulling in a dedicated non-AFCI circuit would make you non-code compliant.
NOTE: HERE IS A CHEAPER SOURCE FOR THE TRIPP-LITE
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-20-2011, 01:46 PM   #18
joed's Avatar
Rewards Points: 11,610
The issue up until now has GFCI, not AFCI.
Old 03-20-2011, 01:54 PM   #19
The panel is right below your treadmill?
killadelphia is offline   Reply With Quote
Old 03-20-2011, 02:16 PM   #20
Tool Geek
PaliBob's Avatar
AFCI breakers also act like GFCI, they look at current leakage.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-20-2011, 05:50 PM   #21
joed's Avatar
Yes but the OP never mentioned AFCI. They are very prone to tripping on treadmills because the speed controllers and brush motors often look like arc faults.
Perhaps the OP is wrong and actually has an AFCI. That would be a reason for it tripping. The long cord is acting like a filter and the AFCI is not seeing the waveform to trip.
Old 03-20-2011, 09:15 PM   #22
Tool Geek
PaliBob's Avatar
Originally Posted by GD Lee;612564 (post #7)
......The breaker is a Sqaure D Homeline AFCI. .......Garry
The OP does have an AFCI Breaker
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-21-2011, 07:19 AM   #23
Tool Geek
PaliBob's Avatar
Originally Posted by GD Lee View Post
Does anyone know if there ia a device, a type of filter, that can be used between a treadmill and an outlet .........
Tripplite makes a premium Surge Suppressor that has toroid chokes and ferrite rod-core inductors that by limiting the initial power on surge may solve your AFCI tripping. I do not agree that your problem is caused by 'frequency spikes' but are surge related.
Because of your treadmills high power requirements I think you should go ahead and pull in a new dedicated AFCI circuit for the treadmill only and use the primo suppressor. It has four outlets but don't plug the computer or anything else other than the treadmill into the surge suppressor because of its power limitation.
also available at Amazon
Disclaimer
& Stay Safe
.....Bob Lavery
Deck nails popping! Replace with screws? sliver108 Carpentry 7 07-21-2010 11:33 PM
Popping noise in the flat roof mtrx Building & Construction 6 03-15-2010 11:18 PM
Treadmill outlet TANC Electrical 3 02-02-2010 10:53 PM
Only one outlet will power treadmill? archer75 Electrical 17 05-05-2009 01:20 AM
Loud Popping Noises - when HVAC is Turned On. San Fran HVAC 2 01-04-2008 10:44 PM
