Is Tray Cable Acceptable For Residential Use? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-20-2012, 11:07 PM   #16
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Originally Posted by mpoulton View Post
USE-2 meets all the requirements and is probably cheaper and easier to find.
Originally Posted by MisterSteve View Post
I now know there is no one perfect wire or cable that can be used in any/all/multi installations/applications. It seems odd that there isn't though........
mpoulton answered your question.
USE-2 in conduit for the whole run.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-20-2012, 11:13 PM   #17
Originally Posted by rrolleston View Post
What two types of cables would you like to splice together and how are they going to be ran?
I need to get from my main panel in my house to the imaginary sub-panel in my garage. Total run of about 125'. 60' in my crawl space, 50' buried and the remaining 15' in the walls up to the panels, both on exterior walls. The plan was to use SER from the main to the end of the crawl space and splice into USE2 outside and take that up into the garage panel. Both being 2-2-2-4 AL.
MisterSteve is offline   Reply With Quote
Old 02-20-2012, 11:13 PM   #18
Rewards Points: 3,256
Here is a question.....what are your soil conditions there? Sharp rocks or clean soil.
zappa is offline   Reply With Quote
Old 02-20-2012, 11:15 PM   #19
Sandy soft salty. Coastal region.
Old 02-20-2012, 11:18 PM   #20
Next question. Would you prefer conduit or direct burial cable?
Old 02-20-2012, 11:19 PM   #21
rrolleston's Avatar
The thing you are going to run into is that splicing the wire with proper connectors taping heat shrink tubing and a large enough junction box is after all that you have spend more money than if you would have used USE 2 in conduit the whole length.
Old 02-20-2012, 11:20 PM   #22
Maybe I misunderstood but I thought the USE2 needed to be rated RHW2 to come within the dwelling unless it terminates within 6' at the panel and is in conduit. Therefore, it CAN NOT be run 60' in my crawl space unless a crawl space is not considered part of the dwelling. Hence, the SER to USE2 splicing. Supposedly there is USE2 rated RHW-2 but is pricey... EDIT EDIT EDIT
Old 02-20-2012, 11:22 PM   #23
Direct burial assuming it is adequate amperage that I would never dream of pulling it up for something bigger.
Old 02-20-2012, 11:25 PM   #24
Exactly, I know those boxes are not cheap along with all the other mickey mouse stuff......ugh.
Old 02-20-2012, 11:29 PM   #25
Why couldn't you use direct burial and then conduit into the structure?
Old 02-20-2012, 11:30 PM   #26
Can I use USE2 in conduit in a crawl space???
Old 02-20-2012, 11:32 PM   #27
Use direct burial where I guess I should ask?
Old 02-20-2012, 11:36 PM   #28
You could but I don't think you would have to. Can you get USE2 in cable form or is it individual conductors. I was thinking of only using conduit when it enters the structure.
Old 02-20-2012, 11:38 PM   #29
It would be individual conductors.
Old 02-20-2012, 11:38 PM   #30
rrolleston's Avatar
Use USE 2 in conduit and direct bury the wire outside 24" MIN below grade. Having the wire in conduit for peace of mind would only add 30 bucks at most to your project. Be sure to order 20% extra just in case because this stuff does not stretch.
In-Floor Heating Cable Trouble... sootybuttercup Electrical 24 12-18-2014 09:01 PM
Running cable under/around laminate floor greenjelly Flooring 4 08-06-2010 10:49 AM
Need help sizing Generator cable dgajr Electrical 2 07-20-2010 01:07 AM
Securing 8/3 cable, are flat metal staples acceptable? Mi Feller Electrical 2 07-02-2010 06:36 AM
Evaluating a kinked cable dave11 Electrical 5 05-09-2010 11:20 AM
