Transition To/from Wirelmold - Code? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-13-2012, 08:30 AM   #1
Rewards Points: 97
transition to/from wirelmold - code?
i can't imagine this is unique but i could not find an answer...i need to come out of a wall (14/2 romex) and enter surface wiremold..is there a junction box/fitting needed? part b of the problem is going from wiremold to a custom wooden molding (it is 3"x5" wooden channel); same question here.
thanks
drgkjd is offline   Reply With Quote
Old 09-13-2012, 08:42 AM   #2
Rewards Points: 13,446
Any way to run that wire behind the wall instead over it in the molding. Sure would look better.
Old 09-13-2012, 09:08 AM   #3
Rewards Points: 97
no..that is why this post. it is a brick wll..yes, theoretically i can rip the bricks, run the wire and re-brick but that would be lot more expensive and risky
Old 09-13-2012, 01:57 PM   #4
Oso954's Avatar
Rewards Points: 986
You can mount a wiremold box over your exit point and another tight against the wood molding, with the channel run between the two boxes. Your choice to blank cover the boxes, or to put receptacles in them.
Without knowing which series of wiremold you are using, it is hard to give you any other answer.
Oso954 is offline   Reply With Quote
Old 09-13-2012, 02:29 PM   #5
Rewards Points: 97
sure-- your question actually makes me ask my second question below:
(btw, this is in dry living space)
1. so far i was assuming i have to use a metal raceway so i was planning around legrand, 500 series, model V500.
2. however, after reading some posts, it appears that i can use a plastic raceway over romex. the question is is that code-compliant?
thanks
Old 09-13-2012, 03:43 PM   #6
Master Electrician
I'm going to take a wild stab because I'm too lazy to look it up right now that your not allowed to run wire in a wooden mold. Pretty sure raceways can't be made out of wood for fire reasons. I could be wrong though, wouldn't be the first time today.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Automatic Closet Lights Sav505 Electrical 52 12-28-2012 07:24 AM
Please Help - Error Code's 31, 32 and 42 on Carrier 58MVB 100 kolo HVAC 15 01-28-2012 10:13 PM
Lighting proximity to outdoor hot tub - Code Question jeffinpickering Electrical 0 09-12-2011 01:43 PM
Bryant Plus 90 Code 31 ~kirkland~ HVAC 1 03-08-2011 06:14 PM
1950's Roof Framing Strength KempLN Building & Construction 21 06-17-2006 10:06 AM
