-   -   transition to/from wirelmold - code? (http://www.diychatroom.com/f18/transition-wirelmold-code-156680/)
drgkjd 09-13-2012 08:30 AM
i can't imagine this is unique but i could not find an answer...i need to come out of a wall (14/2 romex) and enter surface wiremold..is there a junction box/fitting needed? part b of the problem is going from wiremold to a custom wooden molding (it is 3"x5" wooden channel); same question here.
thanks
joecaption 09-13-2012 08:42 AM
Any way to run that wire behind the wall instead over it in the molding. Sure would look better.
drgkjd 09-13-2012 09:08 AM
no..that is why this post. it is a brick wll..yes, theoretically i can rip the bricks, run the wire and re-brick but that would be lot more expensive and risky
Oso954 09-13-2012 01:57 PM
You can mount a wiremold box over your exit point and another tight against the wood molding, with the channel run between the two boxes. Your choice to blank cover the boxes, or to put receptacles in them.
Without knowing which series of wiremold you are using, it is hard to give you any other answer.
drgkjd 09-13-2012 02:29 PM
sure-- your question actually makes me ask my second question below:
(btw, this is in dry living space)
1. so far i was assuming i have to use a metal raceway so i was planning around legrand, 500 series, model V500.
2. however, after reading some posts, it appears that i can use a plastic raceway over romex. the question is is that code-compliant?
thanks
andrew79 09-13-2012 03:43 PM
I'm going to take a wild stab because I'm too lazy to look it up right now that your not allowed to run wire in a wooden mold. Pretty sure raceways can't be made out of wood for fire reasons. I could be wrong though, wouldn't be the first time today.
