Transformers - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2012, 07:41 PM   #1
transformers
can a new low voltage transformer be shorted out ,mine worked for about 5 minutesd then it went out ,and now has no power at all
kev123 is offline   Reply With Quote
Old 09-22-2012, 09:43 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Yeah it can shorted out if the secondary side connections have short circuit it will overheat the transfomer and most small transfomer useally are self protected but not always the case.
What this transfomer is used for ??
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
kev123 (09-22-2012)
Old 09-22-2012, 09:57 PM   #3
transformer
transformer is used for gas light conversion kit 110 to 24 v
Old 09-22-2012, 09:59 PM   #4
Check the conductors on the 24 volt side to make sure they are not kinked or nicked or anything that can cause a shortcircuit it don't useally take much to short out a low voltage transfomer you have there.
Also what the transfomer rating is as well due some case you may have wrong transfomer size. What the wattage of the bulbs itself ?
Merci,
Marc
andrew79 (09-22-2012)
Old 09-22-2012, 11:53 PM   #5
Master Electrician
Yup could just be a simple case of overloading
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
frenchelectrican (09-23-2012)
Timer Switch For 24v Transformers? jesselfout Electrical 12 03-08-2012 04:31 PM
One halogen light fixture 2 transformers half dim. detyianni Electrical 42 01-12-2012 06:32 PM
Installing 9000v neon transformers and a neon dimmer mjkelly93 Electrical 4 12-14-2011 09:37 AM
voltage issues assosiated with banked generator transformers? vaddeboina Off Topic 3 03-11-2010 12:26 PM
Why don't transformers and electromagnents spark up and trip the breaker? Red Squirrel Electrical 9 10-10-2009 11:01 PM
