Transformer Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 06-16-2011, 05:29 PM   #1
Transformer wiring
I have 3 phase 480 power coming into a new building we are building. 200amp approx.
In this building we are going to use the 480 3 pahse and use a step down to run 1 phase 120/240
We are also going to subfeed the 480 3 ph to another building step down to 1 phase 120/240 for lights and misc.
From the second building we are going to sub feed our office with 100 amp of 120/240 power 1 phase
Each subfeed is about 120 distance from the next building.
Question:
Most tranformers I find are 480 primary with a 208/120 secondary on them. The 208 is no use to me.
Do these types of tranformers have two legs of 120 that can make the 240?
How do you get the 240 1 phase?
Do I need a transformer that is 480 primary and 240/120 secondary
LanceG is offline   Reply With Quote
Old 06-16-2011, 07:55 PM   #2
Electrical Contractor
kbsparky's Avatar
The transformers that provide 208/120 output are 3 phase transformers.
You need to get a single phase transformer with a 480 input, and 120/240 output ...
-KB
Old 06-17-2011, 11:13 AM   #3
Rewards Points: 1,532
Main building.Connect 480 volt to 120/240 volt transformertto legs A andB of the 3 phase line. Next building connect another 480 volt to 120/240 volt transformer to legs B and C. Run just legs A and C to the third building (office) and connect up another 480 to 120/240 volt transformer there.
Unusual three way switch wiring help r1racer Electrical 9 11-11-2010 08:49 PM
wiring problem: 120V to 12V Halogen Ceiling Lights with transformer Uncledan Electrical 3 01-20-2010 05:32 PM
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 09:44 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
