Transformer Question, Need Help To Pick The Right One - Electrical - DIY Chatroom Home Improvement Forum
Old 08-15-2012, 12:04 PM   #1
Rewards Points: 20
Transformer question, need help to pick the right one
I have a transformer that recently went out, and need to be replaced.
The one that I have now:
Input 120v - 60hz .5a
Outpout 12v - 60w max
3x20w max 12v - mr16
I'm looking at this one on ebay. Will this work for what I'm looking for?
http://www.ebay.com/itm/Eurofase-60-...item5d349167ab
kevinnho is offline   Reply With Quote
Old 08-15-2012, 01:41 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,860
Yes, that should work fine.
mpoulton is offline   Reply With Quote
Old 08-15-2012, 02:07 PM   #3
Electrical Contractor
kbsparky's Avatar
Or you could use something like this one:
http://www.ebay.com/itm/150748698943
-KB
Old 08-15-2012, 02:26 PM   #4
Rewards Points: 776
Didn't see a UL sticker on it.
curiousB is offline   Reply With Quote
Old 08-15-2012, 04:09 PM   #5
May I suggest that you maybe consider going to a larger transformer? Running a transformer at it's max will cause it to run hot. Heat will eventually lead to premature failure. For those 3 bulbs...maybe go with at least 100W?
I did a quick search on Amazon....more options and much better prices....
At the risk of violating the rules.....here is the link
http://www.amazon.com/s/?ie=UTF8&key...l_4ui8nfmey3_b
jeepdawg is offline   Reply With Quote
Old 08-20-2012, 11:20 AM   #6
Rewards Points: 20
Thanks for the amazon suggestion. Maybe this will last long at 100w vs 60. Otherwise all other specs that It requires, this one will work outside of 100w?
Old 08-20-2012, 11:31 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 838
What do you mean by "this one will work outside of 100w"?
If you mean, can you go over? Yea...for a very short time....you should always try to stay under the rated capacity of a transformer....and if cooling is an issue...under even more or upsize.
A note on upsizing.....
Some people think that if "100w is good, 200W is even better". Yea, it's better if you have the need....but it also means that if there is a wiring issue (say you short the output), the spark and potential fire could be greater.
100W for 3 bulbs sounds comfortable.
ddawg16 is online now   Reply With Quote
Old 08-20-2012, 02:05 PM   #8
Rewards Points: 20
i'm not seeing the 100w that you guys recommended. Will this work? 105w?
BTW: I'll be using 3x20w bulbs.
Old 08-20-2012, 02:43 PM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 838
Is it going to be dimmable?
Old 08-20-2012, 02:45 PM   #10
Rewards Points: 20
Non Dimmable.
Old 08-20-2012, 02:51 PM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 838
The first one on that list is non-dimmable....should work....though looking at the reviews...looks like a couple of them didn't...but then again...Amazon is great about returns. I'm willing to bet the users were trying to use them as dimmable...
This one will also work as dimmable...
http://www.amazon.com/20-105W-120V-D...2v+transformer
Note...these are electronic transformers....they use an ac-dc-ac solid state switching ckt to give you the voltage....not the same as a physical transfomer....
Old 08-20-2012, 02:54 PM   #12
Rewards Points: 20
"Note...these are electronic transformers....they use an ac-dc-ac solid state switching ckt to give you the voltage....not the same as a physical transfomer.... "
Sorry, I don't understand this statement. I'm using it as a transformer to light my 3 light bulbs at 20w each. I'm just wiring these straight out to a 2prongs wall outlet plug?
Old 08-20-2012, 03:13 PM   #13
Rewards Points: 20
I went ahead and purchased this.
http://www.amazon.com/gp/product/B00...ls_o00_s00_i00
Should work?
Old 08-20-2012, 03:24 PM   #14
JOATMON
ddawg16's Avatar
Rewards Points: 838
Should work?
should.............just don't use a dimmer.
Low voltage lighting transformer driving me nuts rjniles Electrical 12 01-26-2012 01:18 AM
Under Cabinet Lighting -- Where to put transformer? jmai14 Electrical 14 11-13-2011 03:09 PM
Central Ac transformer question Rschrei518 HVAC 4 10-20-2008 09:21 PM
Low Voltage/Transformer Question Philb Electrical 3 09-12-2008 08:16 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
