Transformer Question Delta To Wye - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 12:22 PM   #1
Transformer Question Delta to Wye
Hello Everyone
I am new to DIY so I hope I ask this question correctly. I am working on a new piece of equipment. It is going to be temporarily installed at an old facility. The facility has 240v 3-Phase Delta power available. The machine requires 208v 3 Phase Wye with Neutral (the machine has a couple LV components, 120v). How can I make this connection. If I need a transformer, what style etc. Since this is temporary I need this on the "CHEAP". Thanks for any help.
Regards,
Dustin
D-Wade is offline   Reply With Quote
Old 07-24-2012, 02:17 PM   #2
Julius793's Avatar
Sry it's not going to be cheap, and it should ONLY be done by a licensed electrician.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 07-24-2012, 05:14 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Originally Posted by D-Wade View Post
Hello Everyone
I am new to DIY so I hope I ask this question correctly. ...................
What you are describing is NOT "diy" work. It is work that should be done by a qualified electrician.
Old 07-24-2012, 07:37 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 818
You didn't say what the load in watts was...but if it's using 3 ph....I'm sure it is more than just a simple 15A......
Your going to need a 3ph transformer......if you were lucky, you might find one on Fleabay for maybe $1000....maybe.....with the price of copper....I wouldn't hold out any hope.
Otherwise, your looking at several thousand dollars....
Motion sensor with transformer query RealX1 Electrical 4 12-06-2011 02:31 AM
doorbell transformer question Buzzman Electrical 3 06-17-2011 08:49 AM
Central Ac transformer question Rschrei518 HVAC 4 10-20-2008 09:21 PM
Low Voltage/Transformer Question Philb Electrical 3 09-12-2008 08:16 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
