Transformer Question - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2010, 07:16 AM   #1
I have a home alarm system that uses a plug-in wall transformer with screw terminal output. The transformer has gone bad and I am having trouble finding a similar one to replace it with. Here is the information:
Basler Electric
Primary - 120V, 60HZ, 0.43A
Secondary - 16.5VAC, 35VA
Does anyone know where I can find one with those specs? If not, is it OK to use one that has an output of 16.5VAC but with 40VA instead? Thanks in advance for your help!
gatorinsc is offline   Reply With Quote
Old 02-16-2010, 07:36 AM   #2
Yeah no problem.
SULTINI is offline   Reply With Quote
Old 02-16-2010, 09:20 AM   #3
The VA output is a measure of the maximum power the transformer is designed to supply. As long as the voltage output matches and the VA measurement is equal or greater to what you want to replace, you'll be good to go.
HooKooDooKu is offline   Reply With Quote
Old 02-16-2010, 01:38 PM   #4
Thanks for the replies. Are these types of transformers usually sold in local retailers or typically just sold online?
Old 02-16-2010, 01:45 PM   #5
My first though would be some place like Radio Shack or other electrical supply house. Other places might be any retail outlet selling replacement parts for electronics. Even Wal-Mart sells some transformers.
However, there is one more very important thing to look for. I just noticed that you listed the existing transformer as 16.5 VAC (volts Alternating Current). Most transformers are going to generate a DC voltage (Direct Current). So you not only have to match voltage, you also have to match the fact you need an AC output.
Central Ac transformer question Rschrei518 HVAC 4 10-20-2008 09:21 PM
Low Voltage/Transformer Question Philb Electrical 3 09-12-2008 08:16 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Pole Transfomer size question dmarando Electrical 10 07-31-2008 10:09 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
