Transformer Location - Electrical - DIY Chatroom Home Improvement Forum
Old 02-02-2009, 11:56 AM   #1
transformer location
I'm planning to install a new doorbell system and I'd like to know if I can put the transformer in the attic. It's sort of accesible, that is if you want to go up a 15' ladder and scoot accross the beams.
Also if it's OK, can I buy one that's safe with insulation blown in after the fact?
One final question. Is voltage drop much of a problem with doorbells? The buttons and chimes will be spread out over some lengths. Thanks
william p is offline   Reply With Quote
Old 02-02-2009, 05:50 PM   #2
dSilanskas's Avatar
Yes you can put the transformer anywhere you would like. They are mostly installed along side of the panel. How far from the transformer is it to the chime?
dSilanskas is offline   Reply With Quote
Old 02-02-2009, 06:47 PM   #3
Possibly 30 feet away. I hear a lot of folks put the transformer next to the pannel but I plan on tapping into a branch circuit above the living room.
Also, do you know if I run two chimes if I then need to double the required voltage of the transformer?
Old 02-02-2009, 06:54 PM   #4
Rewards Points: 820
Two chimes do not require more voltage. You might want to get a transformer that can deliver more current, if you expect both chimes to be ringing at once.
Some transformers have two sets of output terminals for powering more than one chime.
If both chimes are contained within one unit, you shouldn't even need double taps. You will have a common, and one terminal for each chime.
FW
Ultrarunner2017 is online now   Reply With Quote
Comfortmaker RPJ - Bad Transformer? olgranddad HVAC 2 12-26-2008 12:10 PM
When a pole transformer goes bad Ultrarunner2017 Electrical 39 12-03-2008 10:44 PM
Westinghouse Outdoor Transformer Question dandy Electrical 3 11-01-2008 02:53 PM
Central Ac transformer question Rschrei518 HVAC 4 10-20-2008 09:21 PM
Different color wires on new doorbell transformer.... ConstantChange Electrical 31 11-22-2007 12:08 AM
