Old 11-01-2009, 08:43 PM   #1
Household Handyman
Default Transformer gone wild
I have a re-chargeable flashlight that came with a charger which plugs into a 110 volt receptacle and has a rated input of 15 volts DC to charge the lights battery. Today when I attempted to charge the light, the red "charging" and the green "full" LED's alternately blinked and something inside clicked rapidly. Further investigation reveals that my charger is putting out 27 volts DC instead of the rated 15 volts DC. I used a variable AC--DC power supply I had, set on 12 volts DC (as high as it would go) and the unit seems to be charging as normal. Could something have happened to the original charger and it is now delivering too much DC voltage to charge the light? I'm thinking there is a built-in safety "thingy" which would not allow the higher DC voltage to charge the battery. It sounds as if a new charger is needed. Any suggestions? Thanks, David
Old 11-02-2009, 12:00 AM   #2
Child Alert! Pull Up!
fltdek's Avatar
Any power surges in the area lately? Not real sure but you can send me your charger - I've been looking for something that puts out 27V - 28VDC for a map light that came out of an aircraft. LOL
Whats the cost of replacing the charger? Unlikely to be something repaired.
fltdek is offline   Reply With Quote
Old 11-02-2009, 02:20 PM   #3
Household Handyman
Hey, why not? This charger is useless to me for the intended use, and my shop has enough of those "I'll save it for something later" stuff. I checked it again this morning and it is still putting out 27 volts DC. As indicated, the hole of the tip is (+) and the outside of the tip is (-). The charger has printed on it: Input voltage-110 volts AC/output voltage-15 volts DC. But, that's not what it is doing. "fltdek"--I bet that is an acrynonym for "flight deck", what former Navy flat topper? IF you can use this charger send me some info on where to ship it--I'm serious, I don't want it if I can't use it. I'd rather see someone who can get some use out of it have it. The Halogen spotlight in question is charging fine with one of those adjustable chargers set on 12 volts DC. It may be better for it as it has a 12 volt DC battery in it. Thanks, David
Old 11-02-2009, 03:23 PM   #4
Yoyizit's Avatar
It must be a switcher. I can't see how a linear supply using a 50/60 Hz transformer could ever do this.
Yoyizit is online now   Reply With Quote
Old 11-02-2009, 05:22 PM   #5
fltdek's Avatar
Thurman-
I would be interested in trying it if you are just going to discard the charger. Send a blank e-mail to m.divincenzo@crewstart.com ref Charger in subject line, and I will give you my address. Let me know the shipping cost I will reimburse you or send you a gift card from Lowes or HD. Thanks.
And, it does stand for Flight Deck, but not in the military sense, - private/commercial. Figured it would sound stupid to use something, say like "cockpit" LOL
www.vatsim.net
www.vatusa.net
Old 11-02-2009, 10:48 PM   #6
Household Handyman
fltdek: PM coming tomorrow, winding down for today after keeping sick 3 yr. old grandson with bad head cold. This swine-flu thing has me really concerned when he gets sick now.
Yoyizit: not sure what a "switcher" is. As stated, this charger (or should I call this a transformer?) has imprinted on it-120 volt AC input, 15 volt DC output, and some Chinese gibberish. No switches, or adjustments of any kind. Three tests have confirmed the 27 constant volts DC coming from the charger, and it will not work with charging the flashlight. The "charge" and "full" lights just blink alternately. The variable power supply (transformer?) set to 12 volts DC output works well and is bringing the battery back up. Hope that helps. David
Old 11-02-2009, 11:19 PM   #7
Yoyizit's Avatar
http://en.wikipedia.org/wiki/Switched-mode_power_supply
See
"Risk of equipment damage"
Old 11-03-2009, 12:02 AM   #8
fltdek's Avatar
Thurman -
hey, take your time, more importantly take care of your grandson, we went through the same feeling about a week ago, they had to close the girls school for two days to sterilize, there were 130+ kids that were out sick, and we ended up taking the girls to the docs, there was a 2 and a half hour wait, ironically, the school nurse showed up with her kid...so make sure he gets well. Worry about your transform/charger later.
Old 11-03-2009, 12:05 PM   #9
Household Handyman
Wow! and Thanks Yoyizit. That's some very interesting reading. So, I suppose it is possible for this transformer/charger to be able to have an output higher than it is rated for, but maybe not safely. But, if fltdek wants it, it's his. Thanks, David
Thanks for the kind words fltdek. He is better today, has a serious case of "motor-mouth" now, but I'll take it over the way he just wanted to lay around with someone yesterday.
Old 11-05-2009, 09:08 PM   #10
Household Handyman
I thought this was worthy of posting: I had made a call to "Ultimate Laboratories" regarding the SBS2000H3 High Output Spotlight I own which will not charge. The representative I talked to when I called told me the battery was dead and this was causing the "Charge" and "Full" lamps to blink alternately as they were doing. Due to the fact that I had the earlier model of their unit, there are no batteries available at this time. I heard: Tough luck guy, go buy you a new spotlight. Believe it or not--I got a phone call back from Ultimate Laboratories today. They asked me some common questions as to how long I had the light (app. one year), where was it bought (it was a gift, but was purchased at a Costco store in the Atlanta area), how was I using it (in my home repair business, particularly underneath homes as it lit up everything very well). I was informed that there had been a problem with the batteries in some of the earlier models and my unit was going to be replaced free of charge. I asked him to repeat that, and he did. The will ship me a new model of this spotlight, I ship them the old one back with a C.O.D. label and everyone should be happy. Maybe, just maybe--American owned businesses are starting to stand behind their foreign made products. During the discussion the techy stated that the problem of the blinking lights was one he had not heard of before, so they did need the charger as well to test the old unit. He told me he didn't understand how I could be getting 27 volts DC from the supposedly 15 volts DC output charger. It's going to be their problem now for sure. fltdeck--I'm sorry, but I have to send the charger back with the light now. Thanks, David
More On This Topic
Camera battery charger stops blinking when battery ready. Learn how to install battery for the Canon EOS 40D Digital SLR camera in this free Canon photography lesson. Read More »
The problem is that you can not use one hundred batteries because then my solar panels up there would be not big enough to fill all these batteries. Or the wind power would not be strong enough to fill the batteries. You have to find some kind amount of... Read More »
Recharge your car battery if it is giving you problems such as not starting in a store parking lot. With this option, you may not have a battery that has all of the characteristics as when it was brand new, but it will give you the juice you need to... Read More »
A cordless drill can be an excellent tool for home improvement jobs or commercial jobs. There are many different volt sizes of batteries for a cordless drill. They come in 9 volt, 12 volt, 18 volt and some 24 volt. Of course, the higher the voltage, the... Read More »
Hi! This is Jerry Fishel with Vicious Cycles in Santa Clara, Utah for Expert Village. Have you ever tried to start your bike and had absolutely nothing happen. Well a lot of times that problem can be caused by your battery. What we want to show you today... Read More »
transformer questions Steelhead Electrical 8 10-25-2009 10:39 PM
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 11:44 AM
Comfortmaker RPJ - Bad Transformer? olgranddad HVAC 2 12-26-2008 01:10 PM
Central Ac transformer question Rschrei518 HVAC 4 10-20-2008 10:21 PM
Different color wires on new doorbell transformer.... ConstantChange Electrical 31 11-22-2007 01:08 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
