03-02-2013, 12:42 PM
#16
Transfer switch question.
How many more years are you trying to get out of those 40 year old breakers ? 60-70 bucks would replace them all.
03-02-2013, 01:03 PM
#17
Licensed Electrician
What's wrong with them?
Location...Location...Location
03-02-2013, 01:17 PM
#18
If you have a panel with multiple small transfer switches and you connect up a multiwire branch circuit to two of those little transfer switches and one of them is set to generator power and the other is set to utility power and there is a 240 volt appliance on the MWBC then it is possible to feed generator power up into the utility lines.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
03-02-2013, 01:23 PM
#19
Originally Posted by NJMarine
I answered that in my first post.
You would could install a handle tie on the circuit breakers at positions a&b or intall a 2 pole breaker. The relaince handle tie is connect to the corresponding section in GEN- OFF-Line section.
I guess what I find the confusing point (and I totally blame myself for this) is it seems you are saying I need a handle tie on the breakers in position A & B for both the circuit breakers and the Gen-Off-ON part of the transfer switch.
I'm thinking since the shared neutral circuit breakers in the service panel are not tied together...then that configuration should be duplicated in the transfer switch...two separate A & B breakers (no ties) below and the Gen-Off-Line switch above (A & B position) is the only part handle tied.
If I am wrong here please explain why so I can get a clearer understanding.
Thanks,
Bob
03-02-2013, 03:24 PM
#20
The purpose of the handle tie for the panel breaker for the multiwire branch circuit is so that someone working on the circuit does not flip off one breaker and forget to flip off the other and the work area and neutral are still live.
03-02-2013, 04:52 PM
#21
An old Tradesmen
Originally Posted by Adster
That's exactly what the manufacturers instructions say to do. My only area of fuzziness that I need clarification on is the handle tie. It goes on the Gen-Off-Line upper section of the transfer switch...right?
It would go on the transfer switch, and you would need to put a tie on the breakers also if you are using their single pole breakers for a 240 volt circuit.
03-02-2013, 07:24 PM
#22
UAW SKILLED TRADES
Off subject ... but something is bugging me about the panel guts ? I thought the older tan CH panels had a notched rail and were the same color as the can ?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
03-02-2013, 08:13 PM
#23
An old Tradesmen
Can't say. I can't remember the color of my girl friends eyes half the time. LOL
The Following User Says Thank You to beenthere For This Useful Post:
03-02-2013, 09:02 PM
#24
Electrical Enthusiast
Another off subject...(sorry) What exactly are those cloth-covered conductors in the panel? With the house being from 1933 I was thinking knob and tube, but I see both black and white wires.
Also, I don't know that much about transfer switches, but I would think that you would need to use a handle-tie for the two MWBC breakers, that way both would always be on either generator or utility power at the same time. Is this correct or am I totally off?
03-02-2013, 09:04 PM
#25
An old Tradesmen
Yep, they need to have the handle ties. The OP wa asking about that.
Not sure about those cloth insulated wires either.
03-02-2013, 09:42 PM
#26
Average Joe/ex-Navy IC3
Most likely the OP has BX in his place, since that would date around the time, that it was used. Our place was built around 1937, and had BX in it. Still have some in areas that we have not torn into walls yet to replace it with Romex.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
The Following User Says Thank You to gregzoll For This Useful Post:
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
