Transfer Switch To Main Panel Connection - Electrical - DIY Chatroom Home Improvement Forum
Old 01-27-2009, 10:48 PM   #1
Transfer switch to main panel connection
I'm going to stray from my original thread and ask if this is possible....
Can I take a 6-circuit switch like this one
And use the double pole 240V circuit, and tie into the double pole breaker in my #2&4 slot to feed the entire main box?
Just like the Interlock kit but using one of the switches like the pic.
The remaining circuits on the transfer switch will not be used.
Only reason I may take this route is from the kit prices, just curious.
Also, would doing this void a warranty or not be to code or does a 240V circuit have to feed a 240 breaker and not the entire panel?
i6pwr is offline   Reply With Quote
Old 01-28-2009, 12:21 AM   #2
Rewards Points: 2,350
If you go this route, there is nothing to stop current from flowing back into your main and out of your house. What the interlock does is ensure that when the breaker from the generator is on, it is impossible to turn the main on, and vice versa.
With the way you are proposing here, there is no way to lock the main in the off position.
Old 01-28-2009, 06:56 AM   #3
In the pic above, you cannot have the main and gen on at the same time, thus preventing a backfeed. There is a bracket that won't allow the switches to move towards each other which is on for both.
Old 01-28-2009, 07:09 AM   #4
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
When he said "main" he's talking about the main breaker in your service panel. You're still not interlocking the main breaker on your service panel.
wirenut1110 is offline   Reply With Quote
Manual transfer switch to power an existing sub-panel joestewart Electrical 10 11-23-2009 03:30 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
1 phase generator feeding a 2 phase transfer switch MAP40 Electrical 12 01-01-2009 08:38 AM
Determining Main Panel Load with Subpanel added Randell Tarin Electrical 2 04-11-2008 02:21 PM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 09:18 PM
