Transfer Switch Install For Portable Generator - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2012, 10:48 AM   #1
Transfer Switch Install for Portable Generator
Hi, after superstorm Sandy, we have ordered a 7500W Generac portable generator and a $300 8-10 line transfer switch - all on back-order of course. We have a 200 amp circuit breaker board with about 35 circuits listed, house is 12 years old. My electrical question - most transfer switch seem to only have 6 lines, will I have enough lines to have the generator connected to the board for my electric furnace, well pump, fridge/freezer, security system, and 2 rooms including TV, FIOS connection, lights and some kitchen appliances?
twak21 is offline   Reply With Quote
Old 11-15-2012, 11:13 AM   #2
Rewards Points: 1,192
Well pump,2 circuits,furnace 1. fridge 1, the rest chase out. I like to use a 12 circuit sub panel with an interlock kit that gives you 8 spaces to use.
bobelectric is offline   Reply With Quote
Old 11-15-2012, 11:14 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
Furnace no way.
Well pump could be pushing it.
What kind of kitchen applances?
You are looking at 30 amps at 240 volt with maybe a surge to 35 amps.
Old 11-15-2012, 11:42 AM   #4
Thanks! We should have enough power for the survival equipment (furnace, well pump, fridge) and 2 rooms, microwave plus potentially the oven, added it all up to make sure we had capacity. The generator peaks at 9400 watts. Sounds like 10 circuits for the transfer switch should work? The fridge shares a GFI circuit with the TV for some reason.
Old 11-15-2012, 12:02 PM   #5
jbfan's Avatar
Rewards Points: 254
Is the furnace gas or electric?
Old 11-15-2012, 12:04 PM   #6
Electric furnace/boiler
Old 11-15-2012, 12:14 PM   #7
jbfan's Avatar
Rewards Points: 254
I doubt that will run on that size generator.
generator transfer switch neutral soma Electrical 17 11-16-2011 07:24 AM
Transfer switch for furnace? Ultrarunner2017 Electrical 10 11-14-2011 10:31 AM
Standby Generator & Transfer Switch JRoot Electrical 9 06-12-2011 10:14 AM
Portable Generator Electrical Ground Earnie Electrical 35 01-18-2011 05:53 PM
1 phase generator feeding a 2 phase transfer switch MAP40 Electrical 12 01-01-2009 08:38 AM
