Old 01-29-2013, 07:05 PM   #1
Transfer Switch for Generator
I have 2 electric meters outside and 2 side-by-side electric panels in my basement. Is there a way to hook up a transfer switch for a generator to circuits from both of the panels without moving the circuits?
Dave_T is offline   Reply With Quote
Old 01-29-2013, 07:17 PM   #2
Yes, but you will need two transfer switches or transfer mechanisms, one for each panel.
The advantage of moving circuits to receive generator power to a subpanel is that you don't have to coordinate with the power company to install the transfer switch in the feed line above the main panel and going to the meter. You will still need two transfer switches if you group the circuits that will receive generator power in separate subpanels, one for each main panel and meter.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
Old 01-29-2013, 08:31 PM   #3
You can't have 2 transfer switches hooked up to a single generator, can you?
Old 01-29-2013, 09:21 PM   #4
You can run two tools off one gennie. I don't see the problem. But I may find out
philS is offline   Reply With Quote
Old 01-29-2013, 09:42 PM   #5
Yes you can !
You would need a special type of switch to do it !
A large capacity multi pole switch.
A normal standard type would not work.
Definatly not a job for diy'ers thou.
The switch will be expensive.
something like this
only bigger capacity
dmxtothemax is offline   Reply With Quote
Old 01-29-2013, 11:03 PM   #6
Electrical Contractor
kbsparky's Avatar
Sure, why not? You can have even more if you have the need ...
-KB
Old 01-30-2013, 06:01 PM   #7
How can you have 2 transfer switches connected to a generator? My transfer switch is connected to an outside outlet that has a cable that I connect to the generator during an outage. So I would need two outlets and two cables? I believe the connections on the generator allow only one cable of that type.
Old 01-30-2013, 07:27 PM   #8
kbsparky's Avatar
Some portable generators have multiple outlets.
Many larger generators are direct-wired, and can have as many transfer switches as needed to satisfy Code requirements.
-KB
Old 01-30-2013, 09:32 PM   #9
Both transfer switches, located at the respective panels they control, can be connected to the same line going to the outside outlet (male receptacle) to be fed by one generator.
Each transfer switch's common terminals are connected to the panel that the switch serves.
The Following User Says Thank You to AllanJ For This Useful Post:
Dave_T (01-31-2013)
Hookup..Generator transfer switch to main & sub panel Dick461 Electrical 8 11-05-2012 03:09 PM
Transfer switch between two electric meters? kragan Electrical 16 10-17-2012 12:49 AM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Meter Socket Manual Gen Transfer Switch Mainebob Electrical 3 05-11-2011 08:31 AM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
