Transfer Switch for Generator
I have 2 electric meters outside and 2 side-by-side electric panels in my basement. Is there a way to hook up a transfer switch for a generator to circuits from both of the panels without moving the circuits?
Yes, but you will need two transfer switches or transfer mechanisms, one for each panel.
The advantage of moving circuits to receive generator power to a subpanel is that you don't have to coordinate with the power company to install the transfer switch in the feed line above the main panel and going to the meter. You will still need two transfer switches if you group the circuits that will receive generator power in separate subpanels, one for each main panel and meter. |
You can't have 2 transfer switches hooked up to a single generator, can you?
1 Attachment(s)
Yes you can ! You would need a special type of switch to do it ! A large capacity multi pole switch. A normal standard type would not work. Definatly not a job for diy'ers thou. The switch will be expensive. something like this only bigger capacity Attachment 64624 |
How can you have 2 transfer switches connected to a generator? My transfer switch is connected to an outside outlet that has a cable that I connect to the generator during an outage. So I would need two outlets and two cables? I believe the connections on the generator allow only one cable of that type.
Some portable generators have multiple outlets.
Many larger generators are direct-wired, and can have as many transfer switches as needed to satisfy Code requirements. |
Each transfer switch's common terminals are connected to the panel that the switch serves. |
| All times are GMT -4. The time now is 05:08 PM. |
